Tinted headlights - does it work?
Re: Tinted headlights - is it works?
vr2turbo : You know - I had this plan to want to go start a business cleaning headlights. I'd put a promo pamphlet on any car I come across with a fogged up headlight. Charge RM50 to do only and be a mobile business.
What do you think? Wanna JV? hehe
Must see condition one. Some are really in bad condition. RM50 for both is really cheap......lol
Cannot be too expensive otherwise no one interested. Hehe.. Ok la.. RM50.. per side.
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
Would like to ask who have experience doing this. Is it really works in preventing the headlight from become blurry/haze like.. I duno how to describe but i think you guys know what i mean).
applying clear film on the headlights would help prevent stone chips for sure, but it is not a permanent solution. Regular films from the sticker shops will only last briefly, depending how you drive. Thicker, purpose build films would be a wiser choice.
We are on preventing the headlamps from turning yellow/blur....:driver:
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
Definitely have to avoid parking the car under the sun then
I really think the more the headlights are exposed to chemicals such as, certain wash shampoo, wax the faster its clarity / colour degrade
also, the moment this outer lens has been tempered by means of polishing, it too will head downhill from there and would require more regular polishing
Thinking of it, could it be the heat from the headlamps, because the rear lamps clear plastic do not change color........:smokin:
lsm1991
1,469
185
so.... the only conclusion i have drawn is, we need headlight covers...... and dont drive the car at night....
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
good point, although the taillights doesn't face the sun as much as the fronts
but with today's HID / LED headlights, it's not so common anymore, although they're likely much newer.
Nowadays, some newer tail lights have a clear cover of the red cover which is inside. If that turn yellow it will have the faded color just like in the past those fake or so called Taiwanese imitation tail lights....lol
sweelt
Nov 6, 2016
2,306
248
i did polish headlight yellowish cover for x-gear. Really came off n look new. Using two bottle polish bought from tesco. Rear lamps look like 1st day i bought the car.
Lazy to recall the brand, night shift again. Wira and sentra is glass cover. :smokin:
If just yellow then easy to polish. Some will have crack marks, that will need sanding.....:smokin:
Like this one, did for a friend
This one not too bad...another friend
The Marketplace Top Posts
hi all!
my water level in the reservoir is decreasing annoyingly. checked all- radiator, hoses, cap, water pump, thermostat, all seems to be ok. no water leaking. air air-cond ade la...slalu kuar. ade kena -mengena ke? water jacket bole bocor ke? radiator dah servis, siap tukar head skali tapi sama gak. temperature normal, tak penah naik paras bahaya atau overheat. no loss of power or eniting. keta turbo makan air banyak ke? aku taknak le kena overhaul. so kenkawan tolon le rekemen workshop...
