tyre/tire pressures
mdss
71
9
508
uk
Hi Guys what tyre(uk spelling)/tire pressures is everyone running in their airtrek turbo. My car is running on the standard 16" factory wheels so would like to know the pressures that work best for you on those wheels please.
Inside the drivers door it says 2.1 front and 1.9 rear but that seems quite low for such a big rubber tyre and was wondering if anyone has had experience running other pressures to these?
Thanks in advance
Thanks in advance
The higher the series the less air pressure you require. Even my Chery SUV on 235/60R16 and another on 225/60R17 uses 200 kpa only whereas my VR on 215/45R17 uses 240.
However if you feel wobbly you can increase the pressure slightly, but if too much the ride can become uncomfortable....:driver:
Hey guys,
i running on a 4g93t and plan to squeeze in a little more power into my ride.i heard a 2litre stroker kit can be fitted.question is where can i source the stroker kit from or which garage does,this kinda conversion?it would be great help if you guys can help.
oh ya one more thing which u guys can help me diagnose.my rev kinda fall to below 300rpm and sometimes engine will just die off.is it because of the throttlebody that needs to be replace?it happens once in a while but more...
