Seeking help on turbo boost
kurt_629
872
54
johor
I experienced one time that my car also unable to boost more than 0.5, I thought was the turbo actuator,
but actually required some vacuum hose routing & snap on the "tulang ikan", after that able to boost beyond 0.5bar.
definitely a lot of thoughts and time spent on my car..
some mechanic say its the turbo, advise me to change.
but if its the turbo, why can I still boost to 1 bar when I remove the air flow.
if there's a need to change, I would change..
I just got conned too many times..
I came to know the wastegate is gone, either its fake or sold to me in bad condition as half cut..
anyway, I already inform the mechanic, going to do a replacement for me..
this is the 3rd wastegate..
:smokin:
mnymy
Jul 2, 2012
25
7
503
Kurt..check your Blow Off. If it leak it will trhrow out the air pressure required by the engine to achieve boost. Put your hand in front of it nose and pull the accelerator using your hand..if some air comes out when u open the throttle then it is already damage. The air should only comes out after the desired boost..for standard evo 3 is 0.7 bar. Let us know the finding.
kurt_629
872
54
johor
if standard evo 3 is 0.7bar, that is what I am having now.. :confused:
then how do you explain if I took out the air flow, I can boost till 1.0 bar?
my blow off, is standard Mitsubishi, the black boring looking type, once its throw out, the air will goes back to the engine again
DanzEterna
15,911
3,371
www.primeperdanaclub.com
u r using the std recirculating bov? the air will be directed into the turbine, y not use the external type?
kurt_629
872
54
johor
told you guys, I'm a stock/standard.
nothing is modified..
hey buddy, how are you?
I probably will go genting on Xmas, not exactly the genting but bukit tinggi area.
If you are free, let's do a meet up? :rolleyes:
DanzEterna
15,911
3,371
wassup buddy, fine tq bro
long way till xmas, nothing la in bukit tinggi, genting better
no worries, so far no plans yet....u driving your evo3 during your trip?
kurt_629
872
54
johor
bukit tinggi got nice food, very fresh.
lots of tongka ali for sale. :biggrin:
yeah, once confirmed, I give you a ring.
yeah, the lousy evo 3.. can only boost 0.7 bar.. :banghead:
no money to buy new car.
plus already spend so much to recon the car..
hence had to live with it
Hey guyz need your help here..currently im planing to enlarge / bore my stock trottle body without sacrifie my cold start..below are my question and hope you guys can give me your opinion..
1) Any recommend shop with good workmanship for this mod? Idling will screw up if the workmaship not nice.
2) What is the maximum size i can bore?
3) How much it will cost?
4) It take how long to do this mod?
5) Last but not least is the power. I don expect a huge gain but i expecting improve some...
