Toyota Vios 06 twin pot?
ah2daseng
2
Hi can anyone please tell me what twin pot caliper can fit to toyota vios ncp42 2006..
RENESIS VIII
7,063
950
Ipoh
Depends on how large your twin pot caliper is and whether your wheel size can clear the brakes or not.
First post since joining since April 2006?
Depends how big you want then change rims to accommodate......hhahahhah:biggrin:
Yalor, main thing is whether can clear the rims original size.
I know many join to read, maybe finally got question to ask....:driver:
RENESIS VIII
7,063
950
Ipoh
If original Vios 14" wheels, probably can't clear twin pot.
Well, took him 10 years before finally asking something. :biggrin:
ah2daseng
2
my one is g spec using 15 inch wheel..if can need to use back rotor just want change rotor..i saw people using twin pot caliper for vios 2nd gen and it is plug n play..sori seldom view most the time working..now got time and just start playing toyota vios need some suggestion from u all..
mag9556
2,770
43
1,648
I have saw a lot of vios using ori (not fake one) Endless Caliper.. but with 16 to 17 rim la..
Depends on the brakes and rims design then. Spokes on the outer side then got more room for brakes....
KenDiriwan
1,283
225
kendiriwan.multiply.com
15inch would max clears a 285mm diameter x 22mm thick rotor of twinpot caliper. Common twinpot upgrade are ae111 levin, evo 3, celica st202.
You are able to fit a R32 4pot system as well as long as your wheel below 35 offset.
KenDiriwan
1,283
225
aiya sifu, applies to all vehicle with 15" wheels. Knuckle different bagi convert jer hahahhaa
anyone can help me out here..i need the manual for blitz meter SJ model...i dont have the manual so cannot set the 180kmh cut off..
