hi, i have a 4g15 WISE myself. Being modding bit2. Recently (today) jus changed to 1.6 clutch kit with modded 4g15 flywheel. satisfied, felt plenty of power was lost last time (before change to 1.6 clutch kit)due to previous stock 1.5 clutch kit.
Is it worth increasing by 100cc only.....Hi, planning to upgrade stock 4g15 with stroker kit. for now im looking at 4g18 crankshaft, pistons n con rods at around 900bucks(RM). any idea how much the process of upgrading would cost?anyone have done it before and would like to share?tq
Looks like safest bet. The 1.8 piston is too large, the cylinder wall will be too thin....:rolleyes:hi bro vr2turbo. actually i wan to avoid the process of transplanting an engine. so i plan to try this way :)
1. stroker kit
2. s90 62mm tb
3. 4-2-1 PZ extractor
So far ive done 1.7 inch piping with midbox, hotbits plug cable, open pod simota, 1.6clutch kit with modded 1.5 flywheel.
So if i add all those stated above, any idea of roughly what hp will i be looking at in the end??
1. Waja 4G18 crank shaft + CPS pistons is more than 100cc increase la vr2turbo.hi bro vr2turbo. actually i wan to avoid the process of transplanting an engine. so i plan to try this way :)
1. stroker kit
2. s90 62mm tb
More is like 120 to 130cc only, I was thinking like expand to 1.8 mah!.....hhahahhahah1. Waja 4G18 crank shaft + CPS pistons is more than 100cc increase la vr2turbo.
1. I forgot to ask - manual or auto? What else do you have installed? CAT? S-flow muffler? Resonator?so probably 20hp+ gain on the wheels..i have few doubts :
1. if i change from 1.7" o 2" piping (follow original route) , will there be backpressure low probs? taking into account that i would be changing to PZ extractor
2. mine is VDO, so which tb can i upgrade to? or rebore to 62mm??
tq
4G15 can expand to maximum 1.7L mah. Close enough laMore is like 120 to 130cc only, I was thinking like expand to 1.8 mah!.....hhahahhahah
He change clutch kit from 1.5 to 1.6, sure manual liao......hahhahhaha1. I forgot to ask - manual or auto? What else do you have installed? CAT? S-flow muffler? Resonator?
2. VDO cannot use the S90 TB la. In fact there's nothing much you can do about this other than port match and smooth the TB mouth. If you change to the Satria GTI 1.8 TB that'll work but throttle control will be difficult to control, almost like "on" / "off" throttle (if you know what I mean)
tq
Erm... it WAS manual. I did a gb swap last year. I only got to enjoy the manual for a year!You miss you hero. If manual probably you would have kept.......hhahhahahahhaha
Oh! I thought was still auto......hhahahhahahErm... it WAS manual. I did a gb swap last year. I only got to enjoy the manual for a year!
