Feet Cooler
Swifterific
174
30
Why is it that new cars today shoot aircond at your feet, even if its already on dash aircond only? Its pissing me off so bad :banghead: malam malam want to take a drive switch off aircond = too hot. On aircond = cannot tahan want to piss.
Drove my bro's 208, got forced feet cooler. Drove the new suzuki swift, oso got feet cooler. Suzuki wai yu du dis. Wai. I dont wan my feet to be cold. I dun wan to wear shoes all the time also. :bawling:
Tom
TIMETOATTACK
Jul 6, 2000
5,562
3,229
Interesting. When I go out, I wear shoes every time. Never experienced or thought something like forced feet coolers exists
I think cars with this "forced feet vents" have jammed vents. The new Jap cars I've come across all have working on/off vents. Probably need looking into if they won't close completely
Yup, even my China Chery SUV can switch on and off...:smokin:
Swifterific
174
30
Use masking tape, paste over the vents. Problem solved.
wear stockings......makes you feel sexy oso...:biggrin:
wear socks with selipar very sexy especially when going out at night tt :biggrin: I checked the new swift's feet vent, its just a small box that shoots cold air. i see no vents to close it off. maybe its a bit inside or something. will check more later. if not then i use masking tape ah.
must try leh driving with slippers. the heart attack you feel when your selipar get stuck behind the pedal and you cannot pull away is an experience to experience :rofl:
ken yeang
6,617
1,327
TS, shouldnt there be a temperature adjustment to the AC besides fan speed? the adjustment should be good enuf even the vent is directed below the steering wheel...
Not vents like on the dash. There is a switch next to air con on/off, and temperature. The switch to direct air whether you want them on top, mix top/bottom or to the bottom. You don't have that switch?
I drive with slippers all the time unless have to dress up go official function.....hhahahhaha:biggrin:
---------- Post added at 09:14 AM ---------- 6 hour anti-bump limit - Previous post was at 09:07 AM ----------
Something like this. The switch on the right side.....
ken yeang
6,617
1,327
hahahaha, some frenz of mine even said driving the car bare foot.....to have the best pedal feel wor......
ken yeang
6,617
1,327
if feet numb, then jam the throttle and forget out brake.......is the only way to go fast.....ehehehehe....
Swifterific
174
30
Haiya you guys i come back from raya talk about driving barefoot alredi :rofl: but driving barefoot feel selesa oso what... i tried before. its like driving a manual, you feel a connection to your car :biggrin: :rofl:
Hi guys, I have some problem wif jpj. I wanted to convert my current stocks to 4G93 but have not approved bj jpj coz i currently running in 4G13...I convert to 4G92 mivec and then change all displacement to 4G93 parts use only piston ring and valve. Those other stuffs use hi-cam,adj cam-pulley. Then the engine will run as a 1.8cc...How? Can gip me some advise or else???
