Air filter
BFX73
116
13
theres alot of brand...usually neo owner uses drop in air filter
brand : K&N, works but im using pipercross brand
get it from performance shop or from mudah, its plug n play
for open pod, no idea which is which as i do not use 1...
Open pod if left in engine compartment need to build heat shield also, if not suck in hot air only.....
ken yeang
6,617
1,327
Open pod looks good (some performs well at certain parameter, some say this sort of filter makes nice induction sound), but during bad traffic jam, the filter suck in hot air....
Drop in performance filter would be better...
That is why CAI is important. Some place open pod out to bumper area with long intake hose....:driver:
ken yeang
6,617
1,327
near bumper area is one way to catch cool air. But be careful not to pick up dirt.....and might easily clog the filter.
Whatever the case, please use filters, whatever the type, cheap or expensive, ori or not. Some sohai completely threw away their filter (becoz of "race car" mar).....and managed to suck in foreign things in the process.
BFX73
116
13
yups...and even R3 race car uses drop in...open pod are not helping
Open pod still have the filter at the front end or some call mushroom head filter.
No filter suck in foreign matter get extra oomph and may go kaboom......hahhahhahaha:rofl:
ken yeang
6,617
1,327
or sucking in water, from puddle splashes during heavy rain...
NA engine that suddenly runs "Water injection". Surely ommphh!!!
In the bumper actually quite safe from these water splashes. Main thing should be flood water, because so low down.....:smokin:
Raymondanthony
I don't think open pod will b a good idea. I wil try on works air filter. I have seen a dyno test research that using original air flow will b good in performance compare to open port.anyway tq seniors.
just use ss mesh drop in type..good enough for stock engine
marv3
496
57
Drop-in will suffice. If you lazy to do clean/wash/oil, then get the works stainless steel. Later on, get a hose and join it with the intake, and place a hose further away from the engine (i.e. in front of bumper). Then the engine will be able suck in outside air which is cooler instead of hot air from engine bay.
If use drop in filter, most original hose already draws air from outside, right?
In the dog eat dog world of pick-up trucks, the Isuzu D-Max has always stood out for its impressive fuel efficiency, that coupled with its highly regarded off-roading abilities, makes it one of the strong contenders in that segment.
Now the D-Max has further strengthened its credentials with three of its variants, the 2.5-liter 4X4 manual, the 3-liter 4X4 Single Cab and the 3-liter 4X2 Automatic Double...
