What 6 pots is he using until even 18 inch can't clear the brakes?Forgo the 6 pots???
Of course not fake brembo......hahhahhahahhaaWhat 6 pots is he using until even 18 inch can't clear the brakes?
Cuz kancil only RM90 - RM100 per pieceI got a fren selling 19" 2nd hand tires below market price, so no issue, if brand new already pokai.
yeap its heavy that y planning to downgrade to 18".
---------- Post added at 03:01 PM ---------- 6 hour anti-bump limit - Previous post was at 03:00 PM ----------
I only buy new tyres for my kancil, previous cars all use 2nd hand tyres
min clearance is 8.5jj 18" , hopefully can clear la.Forgo the 6 pots???
Dunno which 4 pot can fit my jetta.min clearance is 8.5jj 18" , hopefully can clear la.
but that day vr2 & izso checked my brakes should be able to clear if using 18" right.What 6 pots is he using until even 18 inch can't clear the brakes?
brembo from mini cooper, the white shark using it......Dunno which 4 pot can fit my jetta.
Did not really check the clearance, go see your 19" rims mah!but that day vr2 & izso checked my brakes should be able to clear if using 18" right.
---------- Post added at 11:27 AM ---------- 6 hour anti-bump limit - Previous post was at 11:27 AM ----------
Don't recall man. But no brembo is that large la especially since it was made for the mini. The largest size I've seen fitted into a mini is 18". But it's not just the size, the offset also mah. What offset is your Vossen imitations?but that day vr2 & izso checked my brakes should be able to clear if using 18" right.
Brakes are part of the wheel and whether the wheel can fit in if have 6 pots system....Why braking system would end up on wheels topic? hahaha :proud:
How to know those wheels is real of fake? Hard to say. But as I know, the smallest size of the wheels they on production is only 19'' . Below than that, all is fake.
Wheels
Btw, can Evo4 2 pots fit into 15 inch rims? on a WiraBrakes are part of the wheel and whether the wheel can fit in if have 6 pots system....
Can with the right offsetBtw, can Evo4 2 pots fit into 15 inch rims? on a Wira
How much bigger are the Evo twin pots. My VR also twin pot with 17" not too much space left at caliper area. With 15" ngam ngam, is it?Can with the right offset
I think he meant by the rims spoke clearance with the caliper i guess?How much bigger are the Evo twin pots. My VR also twin pot with 17" not too much space left at caliper area. With 15" ngam ngam, is it?
