Bnr34 getrag transmission oil
BlueTezza
107
Hi all, I'm wondering which oil should I use for bnr34 gearbox?
I've been searching around forum, some said ATF oil, some said use normal gearbox oil.
So I'm very confused.
And second thing is, my gear stick always feel hot. Anyone has simiar problem?
feezdya
1,814
223
Pee Jay
www.takaful-ikhlas.com.my
Hi bro...you may use toyota supra getrag 6-speeds special fluid which has been produced with the proper specifications that getrag requires.The oil can be ordered from toyota and should be known as the v160 oil. FYI, both supra and skyline getrags are an identical box.
Why your gear stick feel hot is because the might be mechanic left some part (gear bush) that prevent from heat..:adore:
BlueTezza
107
maybe like feedzya said, the heat insulator wasn't there anymore. perhaps it's because of my gearbox has Short Shifter installed before ?
Regarding the oil. I just fill in motul gearbox oil recently. And now need to drain out to change to ATF oil. SAD (wondering can it be reuse for differential ?)
bro,
i bough on toyota le body..which originally 8 valve..then i when bought 12 valve...toyota le engine...i try to insert the egine..oni right hand side....mounting oni can fit....the other moutning....not at all....and the cross..member also not fit.....is there..different cross member for 12 valve?
another thing....the drive sharp.....is it 8 valve and 12 valve same.......plz help me...bcoz im fixing on ma own.....thanks.
