any suggest to replenish the window rubber?
Use spray , or sticker ?
Such small area can you stick a sticker?any suggest to replenish the window rubber?
Can only try plastidip, but if already reputing type where u can see, I actually change the one on my kancil. Cuz is not just faded nor dirty. But Like hardened and reput already.any suggest to replenish the window rubber?
This one must spray patiently. If not, the spots still can be seen hahaCan only try plastidip, but if already reputing type where u can see, I actually change the one on my kancil. Cuz is not just faded nor dirty. But Like hardened and reput already.
Unless take out and dip haha! Have not done it before though, but logically some might flow down into the door panels. Guess, best to take it out to spray kot. :rolleyes:This one must spray patiently. If not, the spots still can be seen haha
Spray 4-5 layers..good enough to cover spotsThis one must spray patiently. If not, the spots still can be seen haha
Guess needs to be closer, guess the spraying on the roof made a mistake. Shouldn't let it dry 1st for 2nd coat. End up have patterns haha!Spray 4-5 layers..good enough to cover spots
Rubber cover rubber only look like rubber ma :rolleyes:aiya no need plastidip so expensive, just go to hardware buy rm7 black spray can & 1 roll or masking tape rm1.50.
tape the surroundings of the rubber strip with masking tape & newspaper. then spray 3-4 layers.
Some of those are hard plastic. Smooth looking, plastic dip is not smooth.Rubber cover rubber only look like rubber ma :rolleyes:
Talk about that, I did refurbish something simple. Will post soon.
Plastidip smooth if done properly Only when job fail then not smooth haha!Some of those are hard plastic. Smooth looking, plastic dip is not smooth.
However some even paint might not stick well. Probably need to sand down first.
Got Black? Not sure about the quality though. I know Carlas have but problem is, got people sapu and sell at higher price. Same thing happened when Plasticdip Black was limited.nowadays have cheaper rubberised spray paint. Got mine for RM20 oni but haven't tested it yet.
But plastic dip can easy come off?Plastidip smooth if done properly Only when job fail then not smooth haha!
Went to search flat black got, but within search haven't seen glossy black.Got Black? Not sure about the quality though. I know Carlas have but problem is, got people sapu and sell at higher price. Same thing happened when Plasticdip Black was limited.
