DIY Honda ECU Repairs- P30 P08 P27
Jun 25, 2014
Perth W.A.
Hi
I have a p06 ecu I'd like to repair it was removed because it had a constant cel light and no fuel prime and no spark. Where do I start what parts should I try replacing?
E-Tech
1,115
256
3,183
Johor
Hi
Hi...
Replied ur PM already.
Sep 25, 2014
Houston
Hello E-tech and everybody in this great forum. I have here a P2E that when installed in the car the transmission shifts poorly. I used a borrwed P2E from another car and it shifts perfectly. Any ideas what could be? or maybe where I could start looking? I am good at soldering/desoldering/reballing bga's etc and have equipment... I just don't know where to start looking. Any help would be appreciated.
E-Tech
1,115
256
3,183
Johor
Hi... Have to let others here to support.
Not my regular Ecu so can't really guide u.
Btw any different in the idling of both Ecu?
And ur car is an auto transmission?
What the last few digit of both the p2E?
Oct 1, 2014
2
33
indonesia
sir,
i have problem with my p08 ecu..
datalog show the tps sensor when full throttle only 6%, and when close throttle is -10%, it's make idle came rought, how i do to fix this case?
i try with my friend's ecu p28 my car idle stable, how must i check in the ecu board?
sorry for bad english
E-Tech
1,115
256
3,183
Johor
sir,
Masalah anda di kawasan ini kalau betkaitan
dengan TPS... semua capacitors wajib di tukar.
kota kinabalu
Re: DIY Honda ECU Repairs-p29/900
Hai,bro, need your helps, my car idle problem , idle up and down very weird , and after check the code, we found code
---------- Post added at 10:31 PM ---------- 6 hour anti-bump limit - Previous post was at 10:25 PM ----------
I found code 14 (aic valve problem) But after I reset the Ecu, it didt show any code, but after I start the car it come out again code 14? FYI I have change all the 7caps. But problem still the same, idle up and down.pls help me,this problem already 4months.pls advise which Ic or Transister or resister have to change it??
E-Tech
1,115
256
3,183
Johor
Hi...
You personal ecu and car?
Send me some pictures by Watsapp....
019-6547373..
Tq
The Marketplace Top Posts
good day guys,im using B16B engine i wanna change those standard extractor and i saw several custom made/brand selling in mudah.com.my but i dunno which one to choose.im prefer those custom made than those from "kedai potong" coz is too costly,its just for my daily use..4-2-1 is my choice.does anyone can suggest me which brand,few brand around and i dunno which one is better.thank for the help.
