Caldina Engine Conversion
tougemax
61
26
Hai. currently driving caldina zt . wanna ask can the caldina old model engine 3s gte ( st215 ) manual convert to my ride.
tougemax
61
26
05 caldina zt FF Ride. less power so wanna upgrade turbo . heard that st 215 is more powerful than st246 . and its manual transmission , i more like manual than auto .any suggestion
har1th7
371
42
my opinion...
even if u want manual, if take halfcut st215 still alot hassle, better take fullcut st246, transfer all (engine, gb auto, front & rear diff)...
then try running first, if everything goes well, then get the transmission & running gear from st215 for 2nd project...
problem faced,
- pedal for clutch will interrupt foot brake,
- transfer foot brake to hand brake, must sacrifice your center console.
propose,
- BOT your current engine
- convert 3sgte auto, but running just fwd (already been done here)
*guys from Russia has successfully convert caldina st246 to manual, try google...
budakkampungaje
317
Dengkil
what i know bout this 3s gte engine is the PS is same 260ps even for st215 or st246....st246 is from model GT-FOUR C edition,GT-FOUR and GT-FOUR N edition for ST215 is model GT-T,GT-T aerial specification ang GT-TS version...only the difrent is st215 have a manual transmission and st246 is only auto transmission and the POWER DENSITY
st215 GT-T
Displacement, cc 1998
Engine model 3S-GTE
Max.power (Net), kw(PS)/rpm 260 ps (191.23 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 33.0 kg*m (323.62 N*m) / 4400 rpm
Power density 5.54 Engine type Serial 4 cylinder DOHC16 valve turbo
Engine information Twin cam
Fuel system EFI (electronic fuel injection)
Turbocharger Turbo
Fuel type Unleaded premium gasoline
LEV system (Low emission vehicle) No
Compression ratio 9
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9
st246 GT-FOUR N edition
Engine model 3S-GTE
Max.power (Net), kw(PS)/rpm 260 ps (191.23 kw) / 6200 rpm
Power density 5.73 Engine type Serial 4 cylinder DOHC16 valve turbo
Engine information
Fuel system EFI (electronic fuel injection) (Ci (central injection)
Turbocharger Turbo
LEV system (Low emission vehicle) Yes
Compression ratio 9
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 9.4
this your spec ZT
Engine model 1AZ-FSE (D-4)
Max.power (Net), kw(PS)/rpm 152 ps (111.80 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 20.4 kg*m (200.06 N*m) / 4000 rpm
Power density 8.62
Engine information
Fuel system D-4 (inside the tube directly fuel injector)
Turbocharger No
Fuel type Unleaded regular gasoline
Compression ratio 9.8
Bore, mm 86
Stroke, mm 86
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 7.1
tougemax
61
26
wao. really good suggestion and many information . thx guys .
Wanggot
3,906
62
Jay Bee
Some frens told that GT4 4WD gearbox will be problem when transplant as FF in a ZT
normality78
3,052
23
5,138
JB
my opinion...
propose,
Care to share on how 3SGTE auto convert to FWD? Can stock GT4 auto convert to fwd?
Ryuuken
204
98
Subang Jaya
