- Aug 5, 2004
- 1,840
- 547
- 3,213
no.But most rota got that size meh?
but "rota" has 7jj with those stupid offsets though
my point is that the width doesnt dictate scrapes.
I have Myvi adjustable. Hi/Lo only. But its a not well-known brand.any idea where can I get those adjustable with lowest price ?
and sifu2 here pls recommend me the adjustable suitable for my case :boring::boring:
anyone here ? pls give me some idea lehany idea where can I get those adjustable with lowest price ?
what means of zangief and dhalsim ?If hi/lo only and your intention is to avoid Sagat, get the hardest spring and absorber and stuff in spring buffers. Make it stiffer than Zangief and less like Dhalsim.
Warning: Too stiff your rear might cause you losing it when going through bumpy road at high speed.
This ftw!If hi/lo only and your intention is to avoid Sagat, get the hardest spring and absorber and stuff in spring buffers. Make it stiffer than Zangief and less like Dhalsim.
Get Hi/lo/soft/hard if possible. Adjust the rear to the highest and front 2 fingers gap lower for rake effect. Tune the stiffness of the rear absorber at the highest (hardest) then take a ride. If the tyre doesnt hit the fender, then reduce the stiffness bit by bit until at a point it juuuuuuustttt ngam ngam doesnt hit the fender.what means of zangief and dhalsim ?
too stiff will damage the rims .. how if i adjust the rear to be higher ? can it works ?
Spinning bird kick !
*Sonic boom!*
Tommy : won't spoil the rims la. Tyres more likely. That Cvkit was saying is that if the rear is too stiff, you won't have stability when it comes to bouncy roads. Make higher yes - but do it properly. Spring buffers will deform your spring in the long term so if your springs are stock and old - then fine. But if they are new and/or expensive - don't la ruin them
I don't think you will like the car if you increase the height, will look bad. Now you actually need to stiffen the suspension as not to let it go down too low to hit the tyre with the fenders...how about hi/lo ?heard that most hi/lo adjustable are stiff too .. coz fully adjustable are expensive for me ...
A shop offer me with hi/lo D2 adjustable , and he said that confirm can avoid body sagat
yea i got ur idea ... anyway can recommend me shops that can get best price of those adjustable ? thanks alot heheI don't think you will like the car if you increase the height, will look bad. Now you actually need to stiffen the suspension as not to let it go down too low to hit the tyre with the fenders...
