How to make a 4age Silvertop sound like VTEC and performance likewise
mh wong
952
159
543
U really make toyota enthusiast shame, y not just play honda, in cantonese "em tong, em sui"
---------- Post added at 06:22 PM ---------- 6 hour anti-bump limit - Previous post was at 06:21 PM ----------
不汤,不水
silvertop madness
21
503
Kuching
mh wong, im sorry if i offended u bro. Just dat i love da screaming sound when both of the engines are in high rev. I know toyota and honda are two very different cars and that their engines are very special in their very own special way. Should we just advice newbies and not accusing them bro. I am also very new to this engine. I know mine is not a VTEC and it would never be one, just that i would surely love it if i can smoke one..heheheh :biggrin:
mh wong
952
159
543
No offend. Just tat i thk is more shiok to hav a toyota which can smoke honda, since many hav perception honda is obsolutely power than toyota. Some toyota enthusiast use supercharger to tapau vtec. Honda enthusiast will said its charger mah, not na wat. Toyota supporter can also blame honda vtec technology mah.
no matter how, im support more on genuine brand. For eg, wat would think if someone driving kancil but emblem is merc or subaru
silvertop madness
21
503
Kuching
Yes bro, dats why I took a 4age silvertop. I know it has very much potential. Just need advice and where should I get started with. .my 4a is still ori, headers and are still stock
D7zul
2,697
848
Shah Alam
hello fellow silvertop owner,
i think u should do this :
- intake, blacktop throttle, trumpet, arc box, toms super air intake, high flow air filter with cold air intake
- header, 4-1 such as hks or apexi
- exhaust, straight flow slightly bigger diameter than stock
- lighten everything, carbon body parts, flywheel, all pulleys, lighter rims
gudluck :burnout:
---------- Post added at 07:55 PM ---------- 6 hour anti-bump limit - Previous post was at 07:50 PM ----------
if u already finish d list above, contact me again n I'll give u another more expensive list of things to do :wink:
mh wong
952
159
543
fastest power up, can do this 1st : -
1) bt 6 speed wiring
2) bt 6 speed ecu
3) bt 6 speed gearbox
4) fgk 421 extractor
5) fuel pressure regulator
D7zul
2,697
848
Shah Alam
2) bt 6 speed ecu
that will work too :biggrin:
Supra_Fanatics
20,673
3,998
2) bt 6 speed ecu
Why not just get blacktop half cut straight? :biggrin:
xtremeleo
3,247
464
5,183
give it a bigger cams, for dat top end power. complement with a torquey zorst setup..
D7zul
2,697
848
Shah Alam
I believe any engine should do stage1 first..
IHE = intake, header n exhaust.. Coz its d cheapest way to get power
After that, can start digging inside d engine for stage 2
KenDiriwan
1,283
225
kendiriwan.multiply.com
I'll tell you what on the sound part.
1. Change to open trumpet
2. Get at aftermarket/custom(unless u found a real good local) header, header won't affect much on noise but it's to pair up the complete exhaust system.
3. De-cat remove catalytic converter, get or custom a whole system with inlet of 2.38 through out the piping. On street there are alot people rojak their exhaust system but 2.38 is being proven best for NA 1.6L engine which is why if you look at aftermarket piping they are all come in that size for NA 1.6L. And be sure the rear muffler to be straight flow type, lot's of choices here HKS Silent Hi Power, Apexi N1, 5zigen ProRacer, 5zigen BorderMax 304(track use only, it's darn loud), Kakimoto etc etc...in the end it's a matter of choices of your ear.
Once you have settled with a proper intake and exhaust setup then we get down with performance talk which too many recipe out there for you to pick, so many ways to increase 4age performance. Talk when you are financial ready.
nappx
2,532
185
5,163
kLaNG-kEy_tEE
little bit sharing:-
How to make a 4age Silvertop sound like VTEC and performance likewise.
wah it difficult but still can do.. but it still depend on your RM
How much MONEY u have? if got 50K.. buy my car..ha ha ha but still kenot tapau hybrid VTEC.
if same CC i believe can smile..
what chasis you use?
finally is..MONEY, Experiance Mechanic, Part & Tuner
Supra_Fanatics
20,673
3,998
Hybrid VTEC as in Honda CR-Z? 0.1L lower than 4age :biggrin:
all sifus..just want to get advice from u all. can or not if i swap the engine myself, full half cut? any difficulties thing appear when i do it myself? my car is toyota ee100 1.3L and to swap to ae101 silvertop manual. i got basic experience about car and technical. what do you thing??? anybody got experience when swap that engine?? any problem appeared??
