EJ-DE on Kancil
E6XLancer
284
6
1 Malaysia
does anybodies here feel the top speed for EJ-DE using on Kancil Chasis with stock 850cc manual gearbox...how about for the fuel consumptions...it is really more save than Kelisa 1.0cc...:biggrin:
kancilkoo
Oct 30, 2010
13
503
im using ej-de on my kancil660..but with 1.0 gearbox..
for long distance, its about 25km/l with ron97
realplayer
330
hi kancilkoo..afew question here....izit EJ-DE is a kelisa engine??..how much you pay for engine + installation?..thanks..
boxxie
15
2
1,503
ipoh, perak
can a k3-ve install in kancil? do they have same engine mounting?
and for the EJ-DE, do they have same mounting with kancil too?
E6XLancer
284
6
1 Malaysia
subframe & chasis needs some modifications...im thinking 100% no endorsement can done with JPJ even those saying them are Most powerful Runner...:driver:
budakkampungaje
317
Dengkil
EJ-DE spec but this spec for japan...
Displacement, cc 989
Engine model EJ-DE
Max.power (Net), kw(PS)/rpm 60 ps (44.13 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 9.6 kg*m (94.14 N*m) / 3600 rpm
Power density 14.83
Engine type Water coolingserial 3 cylinder DOHC12 valve
Engine information Horizontal ranging
Fuel system EFI (electronic fuel injection)
Turbocharger No
Fuel type Unleaded regular gasoline
LEV system (Low emission vehicle) No
Compression ratio 10
Bore, mm 72
Stroke, mm 81
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 5.1
Fuel consumption at 60 km/h, l/100km
same engine EJ-DE is EJ-VE....
Engine model EJ-VE
Max.power (Net), kw(PS)/rpm 64 ps (47.07 kw) / 6000 rpm
Power density 13.75
Engine information
Turbocharger No
LEV system (Low emission vehicle) Yes
Bore, mm 72
Stroke, mm 81
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 6
K3-VE 1.3 DVT...
Displacement, cc 1297
Engine model K3-VE
Max.power (Net), kw(PS)/rpm 90 ps (66.20 kw) / 6000 rpm
Max.torque(Net), N*m(kg*m)/rpm 12.6 kg*m (123.56 N*m) / 4000 rpm
Power density 10
Engine type Water cooling serial 4 cylinder DOHC16 valve
Engine information DVVT horizontal ranging
Turbocharger No
Bore, mm 72
Stroke, mm 79.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 5.4
K3-VE2 DVVT n/a this is my favorite engine for k-car...
Engine model K3-VE2
Max.power (Net), kw(PS)/rpm 110 ps (80.91 kw) / 7000 rpm
Max.torque(Net), N*m(kg*m)/rpm 12.8 kg*m (125.53 N*m) / 4400 rpm
Power density 8.18
Turbocharger No
Fuel type Unleaded premium gasoline
Compression ratio 11
Bore, mm 72
Stroke, mm 79.7
Final gear ratio
K3-VET....DVVT turbo
Engine model K3-VET
Max.power (Net), kw(PS)/rpm 140 ps (102.97 kw) / 6400 rpm
Max.torque(Net), N*m(kg*m)/rpm 18.0 kg*m (176.52 N*m) / 3200 rpm
Power density 6.79
Engine type Water cooling serial 4 cylinder DOHC16 valve IC turbo
Engine information Horizontal ranging DVVT
Turbocharger Turbo with intercooler
Compression ratio 8.5
Bore, mm 72
Stroke, mm 79.7
Final gear ratio
Fuel consumption at 10-15 modes, l/100km 6.4
kanthang
23
1,503
Bro, I am interested in the engines you have listed here. Can you give me an indication of the costs at present and a reliable source. I am planning on changing my stock Kancil 850ex carb engine for a higher cc with EFI. Thanks in advance
4gbanger
Jun 26, 2013
1,958
386
683
Johor/ShahAlam
i did saw one kancil with K3VET in johor. but im very damn sure it cannot be registered. there are even 1 kancil that install 1.6L detomaso engine in nilai/seremban area... big balls
Supra_Fanatics
20,673
3,998
K3VE or K3VE2 in Kelisa is good enough for me...:love:
Hello All....
after much deliberation, i have decided to paint my car sumwhere in usj1 area. they have all the necessary equipments n enough experience as a painter..... as for the price, not as cheap as i hope it would be but it is based on my request also that they dont use cheap materials.... more or less i wanted mid-range to high-range....
original colour: burgundy by PPG, code p48 a0086
new color: based on same colour code but will bancuh with more black to achieve 40% darker...
