i replaced my short drive shaft with new ones from Cycar RM150, since i was using 6a12tt manual, there is no new DS for the long shaft, therefore i need to send it for recond, they charged me RM100 to replace both joints. u can recond your long DS as long its not bend, cracked or broken.i thought 6a12 still on speed cable? got come out weird noise or not?
Danz, normally how much u get charged to replace Driveshaft? i got charged 500 to replace those 2nd hand include labour, but till now prob didnt settle. CyCar called me and inform that ipoh got some dealer, so if the price is good i might get xtra DS to whack the mekanik for failing to rectify the damn problem after so many trip.
so additional problem that mekanik highlighted is the engine mounting. He mentioned that the engine is quite close to the chasis / under bar. i have nvr peekaboo other 6a12tt so not sure if its like that or some prob occur.
also the exhaust piping is kinda hitting the rear link, i think its rear subframe link or something like that. the name just couldnt come up to my head now. geez. so you think got any bad effect?
Marshal and Namejoker, 6A12TT !!!!!
white smoke sometime valve seal, sometimes piston ring, sometimes turbo kong.hahaha..the time will come..need to jinak2 with high speed first..cannot jump straight to high power...6a12 sound nicer..haha
u do piggyback first..i want to see the gain..worth it or not..hahahaha..
same mod as mine..after stabilizing my electrical equipment..
just ordered :
-dayco timing belt kit
-iridium spark plug
-best i cable
next will be hotbits exhaust part, not sure to do full or only extractor and rear section or only rear section. the sound quite nice
IINM white smoke only cause by the seal..
perdana use speed cable connected near the rear mounting point on gbox.I want join 6A12 auto
my km/h meter not running emm sensor maybe
Bolt On Turbo (BOT) not advisable la.laterlaa...hahaha...6a12 + tt not advisable? low boost only
wow high boost TT nih..if u plonk in powderful engine, the chasis need upgrade. 6a12tt not slow. u just got to experience it first. indeed in stock form the boost not that high.mine is at 1bar.
serious? grounding cable give 9.7hp, that's not bad..maybe will go for overhaul only and add little mod. if got extra car maybe can put the perdana for project car. scared car always stuck in workshop. somemore still satisfy with the performance and FC. can go more than 500km in full tank in daily drive(most on highway).
bang neuro, see u next week. tonite will go back hometown. next week i'm free, my wifey will not joining so can borak more on car.
how about eletrical current? is it good to grounding our perdana? which part we can connect the grounding cable?
claim by using Qmax Nano Technolgy Grounding Cable, it increased 9.7hp through dyno test but the price is expensive. you will be surprise.
Proton Perdana V6Photo Conducted Dyno Test the best grounding kit.hks grounding cable,kicker grounding wire,audison power cable,
i follow one old thread where to connect the grounding cable.
yes. better focus on rebuilding my engine rather than changing on little mods that do not add/add little power to my car.my bro in law using a modded evo3 engine but using rm5 per pc RXZ spark plug.
dun believe that plugs will give u add hp, all bullshit, it will just increase the lifespan of the plugs so no need
to change so often as workmanship to change plugs in pv6 costs rm180.
that car belongs to one of Vsixers member.maybe will go for overhaul only and add little mod. if got extra car maybe can put the perdana for project car. scared car always stuck in workshop. somemore still satisfy with the performance and FC. can go more than 500km in full tank in daily drive(most on highway).
ya my speedometer, odometer n tripmeter not running. ...... tacometer still runningperdana use speed cable connected near the rear mounting point on gbox.
maybe speed cable rosak or meter rosak.
ur odometer and tripmeter jalan tak?
since all the meters connected to the speed cable is not functioning, i guess ur speed cable/sensor at the gbox rosak.ya my speedometer, odometer n tripmeter not running. ...... tacometer still running
currently using denso spark plug so far ok
Did you install piggyback? If yes check the speed cut removal wire is it came off already. I had the same problem as you, checked everything at last found the speed cut removal wire came off from my piggyback..ya my speedometer, odometer n tripmeter not running. ...... tacometer still running
