Help,my cefiro a32 cannot go straight
cheong
17
kuantan
Hello everyone,my case is when go straight,the car makan left,but after i turn right,the car will makan right on straight way,but only awhile,after that the car will makan back left on straight way
if i make a left turn,the car will makan left more teruk on a straight way.
i already change the absorber,absorber mounting,lower arm,bush,steering rack,and new tires(front).
the foreman say tyreman problem,i already try 2 tyre shop for alignment,also cannot fix,then the tyreman say foreman problem,aiyo,what to do somemore,pls help,thank you in advance.
12savefuel
195
75
You need to check all the rear suspension bushings on the beam axle, control arm etc in the rear. There are many there, check if they are cracked or broken.
cheong
17
kuantan
Alright,will check them 1 by 1.thanks for the info bro
cheong
17
kuantan
hey guys,i have done the absorber ball bearing,some front/end bushing,tie rod end and alignment.
the car is better than last time,it can go straight,but just for certain road,mean when i using my iswara at some road it will straight,
but my cefiro will slightly pull left (no more pull right this time)
is it tyreman problem?
12savefuel
195
75
My a32 will pull left when you have hands off the steering. Have been like that since new. But if alignment is done properly when you hold the steering straight it must track straight.
Yes my car will not track straight and tends to follow road conditions at times. Therefore sometimes the steering is either slightly right or left to make the car track straight.
But my a33 doesn't have the problem, partly because they improved the rear suspension layout and added super toe control.
cheong
17
kuantan
yaya you got me,hold steering it straight,hands off it pull left sometimes.
so mean this is normal to a a32 la?
12savefuel
195
75
Yes. Mine did that even brand new from day 1 and still like that 300,000km and 16yrs later. :biggrin: That's the only real flaw in the A32 personally. Thank goodness they improved it on the A33.
cheong
17
kuantan
okay i get it.but even is like this,it is more better than before lo,before i cant get my hands off the steering just for a second.so thanks for yours and others info lo.thank you very much.:wavey:
ixeo
4,788
3,080
KL, Malaysia
Sometimes, the car just wasn't born straight... just saying... Sorry i got nbtd. cabutz.
The Marketplace Top Posts
Guys...
Where can I buy a cheap yet reliable & effective Voltage Stabiliser for my car? I've read a DIY Voltage Stabiliser but I'm no good in electronics and soldering.. :smile: :smile:
