Upgrade 16 inch I fully supportvr2turbo, what 195/55/15 tyre has super stiff sidewalls? C-drive2 bloody flexes when I push it a little harder and that flex movement is a bit scary. I need something harder otherwise I'll have to upgrade to 16"
hmmm... super stiff?....Yoko Advan Neova AD-08.....vr2turbo, what 195/55/15 tyre has super stiff sidewalls? C-drive2 bloody flexes when I push it a little harder and that flex movement is a bit scary. I need something harder otherwise I'll have to upgrade to 16"
Federal RS-R, Nitto NT-01 but size is 205/50R15
Something more for daily use
Potenza RE-002
Yoko S-Drive
I need 55 profile. If I have to go down to 50, I might as well spent a bit more to get 205/45/16. Stiffer and won't affect my ride height. 50 profile on my car looks too small la. Used to use 50.He just wants a tyre with stiff sidewall.....
I think you used 195/50R15, right? If yes, they are more than 3.27% smaller.I need 55 profile. If I have to go down to 50, I might as well spent a bit more to get 205/45/16. Stiffer and won't affect my ride height. 50 profile on my car looks too small la. Used to use 50.
RE002 I haven't really explored but S-drive doesn't have 55 profile. Not in my area here anyway. Which is kinda weird and are you sure S-drive is hard sidewall?
er... I am using 195/55/15. I used to use 195/50/15 but it was too small on my car. I want to stick with 195/55/15 or go up to 205/45/16.I think you used 195/50R15, right? If yes, they are more than 3.27% smaller.
This is 205/50R15 which is 1.6% smaller only.
The stiffer sidewall ones are the extreme tyres AD-08, RSR & NT-01
RE-002 and S-Drive harder then your soft C-Drives, but not as stiff as the extreme ones, that is why I mention more for daily use...
Then forget RE-002 and S-Drives.er... I am using 195/55/15. I used to use 195/50/15 but it was too small on my car. I want to stick with 195/55/15 or go up to 205/45/16.
AD08 is way outta my budget range. I'll have t look at NT01 or the GT Radial SX2. I assume that's relatively hard?
Btw, I'm asking for track use. So don't care too much about comfort.
205/45/16 got more choicesdamn. So it's hard to find decent tyres for 195/55/15 and 205/45/16?
actually for 195/55/15 no its not... theres quite a number of options in this size since its a very common size.. just that its a lil bit more expensive than 195/50/15damn. So it's hard to find decent tyres for 195/55/15 and 205/45/16?
Yup, can try NS2R...R1R is available in that size, decently stiff sidewall aswell.
edit : might be out of your budget
How about NS2R?
Nope, sidewall too soft for him.....price check for
1. goodyear f1 gs d3 + 195/55/15
2. toyo proxes t1r + 195/55/15
*dont use falken ziex 912 + cc2
SX2 got to wait, size not out yet for 195/55R15 and he does not want 195/50R15, but have been pushing him to use 205/50R15.....actually for 195/55/15 no its not... theres quite a number of options in this size since its a very common size.. just that its a lil bit more expensive than 195/50/15
NS2R, SX2, R1R, potenzas, ad08, r888etc etc...
but i think for track use, the cheapest would be the NS2R and mebbe SX2
if ur willing to look into 205/50/15 then theres the RSR and KU36 to look into. sidewall height is only 5mm lower than 195/55...but u get an extra 10mm of contact patch which equals to more grip :D (noticeable or not is an entirely different matter heheheh)
bro... looks wise... 205/50/15 is significantly fatter than 195/50/1550 profile is too skinny looking on my car laaaaa... right now already kinda weird looking if I don't use 16" or 17".
And what brand tyre is NS2R? Nanking? Never heard of NS2R
As mentioned by bro. Madman, if you use 195/50R15 then the sidewall is too narrow, almost 10mm lower, but if use 205/50R15 the sidewall is lower by 4.75mm only, but with 10mm wider pattern. Overall 1.6% smaller only compared to 195/50R15 which is 3.27% smaller.50 profile is too skinny looking on my car laaaaa... right now already kinda weird looking if I don't use 16" or 17".
