Brake problems with saga blm
Jul 5, 2013
:hmmmm: Hello there, first warning is that I am absolutely clueless about the brake system in the car.I own a baseline Saga BLM 1.3.
Recently my car has been making groaning noises when i brake and also a high pitched whistle...
I also got into a minor accident 2 days back. i did press my brakes, and i felt it clicking-but the car seemed to just slide on forward as if it was on ice.
I was not speeding and i braked quite far away and yet it couldnt stop in time.
What is wrong with the brakes? ought i change my brake pads? I did change them to Bendix recently,bout 4 months back..
Help is so very much appreciated, thanks! :adore:
kazukimy
638
372
1,563
KL/Pahang
devil-home.blogspot.com
if using bendix is normal to have sound, groaning?
lots of things could caused this, 1st your speed, 2nd your tyre, 3rd your brake pad, 4th your brake disc 5th your brake fluid 6th brake pad installed wrongly and etc
when you are using stock brake pad, do you have the issue of not being able to brake in time?
best answer to your problem is.. if still under warranty send back to SC to have a check up on it, else just send to workshop to have a look at your brake
Slide? maybe your brakes work, but tyres bald so it silde?
aHLengChai
380
53
i also own BLM 2008/09. 1st model.. send your car to workshop and ask them to check your rear brake caliper + pump.. it might be jammed..
Currently in a waiting list for the Civic 2.0... My girlfriend commented that the front of the car is rather long as compared to other sedans, hence i was thinking of installing a front sensor or alternatively a front camera..
Can anyone here share the difference? In terms of functionality and pricing? Any recommendations?
I am still more incline towards fixing a front sensor as i think the camera will cost more and i would need to fix a display unit in the car.
How does the front...
