Tire Size Talk....
lexuskoh
585
4
Rim 17" x 8jj....which width better should go...?
min 215 can ?
then how about max width ?
min 215 can ?
Depends on what aspect ratio of tyres being used.
If 215/45R17 then 8 " is max, as recommended is 7 to 8.
If 215/50 or 215/55R17 then 7.5 should be max, as recommended is 6 to 7.5
lexuskoh
585
4
How about 225/45/R17 for my rim 8jj ?
Cox the halfcut rim tire is 245/45/R17 ...but the tire cant use
Some more makan minyak too if use 245.
As bro. 6UE5t mentioned 225/45 is perfect for 8" rims, as recommended is from 7 to 8.5".
Even 245/45 can fit 8" (recommended 7.5 to 9")
Would like to ask, what is your original tyre size on your ride, as you cannot just fit any size you like.
For example 245/45 is almost 3% bigger in overall diameter over 225/45, so please check your original size tyre and convert from there....:driver:
---------- Post added at 08:15 AM ---------- 6 hour anti-bump limit - Previous post was at 08:08 AM ----------
how about rim size 18" x 8.5jj, what is the most suitable tyre?
18" x 8.5J, you can fit from 225 right up to 255. It also depends on the aspect ratio (series) used.
As mentioned, please convert upgrade size according to your original tyre size.
xuang26
80
508
Selangor
Hi vr2turbo. Thanks for ur reply...my rim is 18" x 8.5jj offset 32. Which size of tyre u think most suitable...235/40/18 or 245/40/18 or 245/35/18? or any recommendation?
What is your ride original size?
lexuskoh
585
4
Now my car mark 2 jzx100
Front rim 6.5jj 205/55/R16
Behind rim 7.5jj 225/50/R16
I want upgrade to 4pcs rim 17" x 8jj offset 25 (all same offset)
And I planning upgrade toyota 4 pot front brake system
So want saiz tire should I choose ?
225/45/R17 would be best for you.
Yup, as bro. 6UE5t mentioned 225/45R17 almost same overall diameter as your current tyre size.
If you want rears to be wider then 245/40R17.
Offset 25 seems a bit further out, maybe that is what you want...:driver:
Hi all sifus...
I'm driving a Wira. I saw some cup holder at Brothers, the one to install just under the center aircond vents. thought of DIY it. Anyone tried it b4?
