There are 2 possibly answer of bottoming out,I see.. Now I know that Eibach spring will cause bottoming out with 5 people on board. Good info for potential buyers like me... But, if we use absorber with stiffer damping rate, will it still bottom out? I'm very interested in Eibach spring, but I also want to do it right the first time..
---------- Post added at 04:50 PM ---------- 6 hour anti-bump limit - Previous post was at 04:49 PM ----------
Eibach (ProKit) is lowered spring.
Yup, this is what they told me la.. so far so good.. maybe based on the picanto stock abs is different as the stock really vy soft.. before that i only use lowered springs, my stock abs died off like 3~4months..60% stiffer? Mine only 25% already solid woh!
l2s_turbo, may I know what spring do you use in your gf's picanto? Where did you do the custom absorber and also what brand?There are 2 possibly answer of bottoming out,
1st because Eibach springs are not that hard and the spring rate is much softer than others such as Tein, but it's a little bit stronger than stock just that it lowers your car with comfort.
2nd because the absorbers were also stock, so when you lowered your car, the car tends to sit lower than the original stock position, so when you carry 5 person's load, the car will sit lower and stock absorber will let your car sink even more compare to those aftermarket absorbers.
What i did to my gf's picanto was, using lowered springs + custom made to order absorbers where the damping rate is 60% higher than stock. It works fine with me.. not too bouncy and not too soft when taking high speed corners.. unless you opt for fully adjustable..just my 2 cents of experience...:rolleyes:
Hi Megpan,ive just fitted my forte with Eibach pro-kit, i can say it improves the handling a lot, stiffens the ride a little but acceptable. makes my ride more garang too :P got it for rm1150 minus workmanship
