Suzuki Swift: 1.5 (m15a/zc21): Discussions/Opinions
satria_95
6,746
18
5,138
Malaysia
vyrusj,
where does the air go in front? can't really see the opening.... or am I missing something ? hehe
vyruzj
190
3,018
vyrusj,
Bro,
This B-Crew airbox you have 2 options - using b-crews grill or using original swift grill. I am using original swift grill. right behind the grill, there is a air funnel which is connected to the air box.
Original b-crew grill:
Air funnel:
More info on the air box and the funnel setup which i am using:
http://tykoh88.blogspot.com/2010/06/air-funnel-intake-from-project-s.html
satria_95
6,746
18
5,138
Malaysia
vyrus
the b-crew grill looks quite nice. More like a direct air intake. Did you have any issue when driving through thunderstorms or heavy rain? From what I know, stock air filter intakes are usually facing downwards so that it's difficult for water to go up the pipes. If it's frontwards, any issues?
vyruzj
190
3,018
vyrus
I have not had any issue while driving thru heavy rain and thunderstorms. If you see the design of the airbox, the flow of the air come at the lower portion of the air box then goes up then only reaches the filter. The filter tends to get dirty fast, i blow clean the air filter every visit to the mechanic :)
satria_95
6,746
18
5,138
Malaysia
Air filter getting dirty is better than water getting in. haha But yeah, I looked at your pic again, the air has to travel upwards at the engine section. Any idea how much is the b-crew grill setup, with the airbox and all that, and where can I get them?
vyruzj
190
3,018
I got it from another forummer when upgraded to open pod filter at RM8XX if i remember correctly. The nearest place to get it new will be in singapore. Try creating an account in Swiftclubsg and ask the merchant there - Project S. If not mistaken they have a partner here as well Trial Tuning. New ones will set you back for RM1.5K i think...
satria_95
6,746
18
5,138
Malaysia
that's kinda expensive. I'm actually looking at just the box and grill. haha will check out swiftclubsg :) thanks dude
AisBerg
Nov 15, 2012
31
2
508
Hi guys...glad to see Swifters around here...I've never met Swifters for real but for a good start, I think I should join this thread...feels the similarity...Mine is stock 1.5 2005 has clocked 205000++ km & has done some repairs on engine...
I also have the same issue about the performance...Modding cars is really fun to look at & I love to hear the sound of modded engines especially V8 & racing cams...If budget is an issue, can you guys recommend on which one would be the 1st thing that you do to increase the torque(engine response) & what are the next mods. Hopefully, this question makes sense... :)
1 - gearbox
2 - ECU
3 - camshaft
4 - others if any
thanks in advance for your replies.
Imprezho
70
6
5,008
Imprezho,
Hey, dude. Thanks for your comments. Yeah, most of the swift threads are dying or already dead. Even singapore's swift thread doesn't gain a lot of popularity. Kind of a waste because swift is actually a nice car to drive in, other than the occasional bad body roll and the bit of slack in over all performance.
1) Performance
I was reading your last line in performance;
"- Servicing done: HONDA 5W-30 engine oil, oil filter,air filter,NGK laser plugs,cleaned throttle body, 2 new ignition coil plugs,ATF oil, engine flush."
I was using suzuki engine oil because of the 8 free service coupons which covers oils and labour. I got 1 more service coupon to use so I might as well use the last one and after that, I plan to get my own oils, etc. some questions if you would not mind.
a) Do you get your own oil filter and air filter too? Or you use the ones that the service center/service shop provides?
b) Have you been using the NGK laser plugs for long time or you just changed it during the recent service?
c) Did you change the ignition coil plugs because it was time to change it, or was it to improve something in the car, or was it already becoming faulty?
2) Car noises. I'll try removing the driver seat and use wd-40.
3) Handling. I think your car may be built better than mine in this area as yours is CBU and mine's CKD. CKD probably stands for Che Kai Drivability. (che kai means lousy in cantonese) hahaha. Will add in the bars commented by ixeo in his post and see how much improvement i get out of it.
4) performance. I'll try out the Honda 5w30 oil that you mention probably in my next 2nd service. The upcoming one, i still have the free coupon so I'll just use that one more time. But I'll need to change the plugs because it's up to 35,000 kms and the plugs are not changed yet.
Thanks for your feedback. Will be back for more updates when I have them. :)
Ixeo,
Thanks for sharing. For the stabiliser bars, I'll keep in mind your advice on engine tower strut bar and rear anti roll bar. I've not sure if my swift already has a rear anti roll. I'll check it out later and if it doesn't have, I'll get that first.
For performance, I agree with you on the turbo. Pay big sum one time, get big power immediately (so to speak). Speedworks complete AXT turbo kit is RM8000, all in. They didn't say what's included in the "all in", though. Adding bits and pieces gets much less power but easier on the wallet. I don't actually intend to squeeze a lot of power out of this car because I am hoping to change a more powerful buy-n-drive car in about 1 or 2 years time. Maybe a car with stock 160 bhp, or something equivalent to a mazda 3 sport would also be fine. That's why I'm considering adding some bits and pieces for a bit more power on the swift for now.
By the way, I noticed that you sell Denso or Iridium. Some questions if you won't mind :)
1) how much are the iridium laser and the normal iridium plugs for swift?
2) what is the diff between laser and non laser iridum plugs?
3) any warranty? If yes, what and how does the warranty cover?
4) anything I should know before i buy and install it? don't worry, I won't expect 10% increase in bhp just from the plugs alone haha :)
Hey Dude,
1a) Yes i do normally use my engine oil and oil filters by myself as im just skeptical on getting from outside as i have my personal supplier that supplies lubricants,parts, wear and tear stuff.
b)Been using these plugs since my 70k mileage as i have just changed it at my major service 80k mileage strikes.
c)Ignition Coils were replaced due to abnormal jerking/ combustion problem at 80k mileage interval.Got it replaced with my plugs during this time as well.
**Updates so far for my swift observed at 82kmileage is that fuel consumption has improved alot as im clocking in at 380km for one full tank. Im yet to reflash my ECU to gain further improvements of this ride**
---------- Post added at 04:53 PM ---------- 6 hour anti-bump limit - Previous post was at 04:49 PM ----------
Guys,
It would be a great meet up for a drink to chillout and talk about cars too. It will be more like a small TT to intro ourselves and discuss ideas too
vyruzj
190
3,018
1 - gearbox
2 - ECU
3 - camshaft
4 - others if any
Wow... u must be one of the first batch of Swift owners. I got mine in year 2008, current mileage is 130k km.
I think the basic IHE would be recommended for engine mods, as for handling i'll go for ARB and strut tower bars..
---------- Post added at 04:43 PM ---------- 6 hour anti-bump limit - Previous post was at 04:40 PM ----------
Hey Dude,
Guys,
I have change my coils during 80K km as well - same symptoms and issue with urs. Currently i am hitting 420-460km per tank on my daily commute from Seri Kembangan to Cyberjaya.
ECU reflash by DKtuning? or u plan to piggy back the current ECU?
Imprezho
70
6
5,008
Nope not by DK tuning. Found a specialist named DESMOND from POWER AUTOHAUS in Sunway.
In the midst of getting it reflashed. Any one else interested?
l2s_turbo
1,068
154
wow suddenly swifters appear.. i was searching high and low for you all.. i thought nobody likes to play swift already.. where as in singapore still tonnes of nice cars here...
vyruzj
190
3,018
How is the price like? Downside of DK tuning is that he is located in Penang :( I still got few more wear and tear things to fix - engine mounts, lower arms, etc... before i can go for reflash.
Do share with us the results ya! ;):adore:
---------- Post added at 09:38 PM ---------- 6 hour anti-bump limit - Previous post was at 09:37 PM ----------
How is ur brake feeling now bro? Now u have better braking, next up is the performance rite? :biggrin:
AisBerg
Nov 15, 2012
31
2
508
actually, i'm the 2nd owner and it reached 90k++ km when i bought it..to me, swift is rather fun to drive as compared to Honda Jazz 1.4...it might different if the engine was 1.5...
btw, i don't know what IHE stands for? hehe..still a beginner & learning...
vyruzj
190
3,018
Hi Bro,
IHE = Intake, Header & Exhaust
These 3 are the basic upgrades u can start off on your car modifications. Intakes will be the air filters, header is the exhaust manifold or extractor and lastly exhaust... err basically the exhaust system after the header till the muffler.
Since you are driving 1.5 swift which is running on throttle cable, i recommend u to tighten the cable link to the throttle body. I have met some swifters last time, the link from the throttle cable to the throttle body has some slack/freeplay hence when we step on the gas the response abit slow. So try to get ur mech to tighten the throttle cable link to get some better response. This will not increase any hp/torque just better response.
If IHE still not enuff, then u can try more advance mods like you have mentioned - change gearbox, cams, etc...
In some installations, there is provision for a plastic container containing a sort of oil to be squirted into the upper cylinders in order to reduce the higher operating heat and thereby prolonging engine life.
Tufoil with its record low coefficient of friction helps considerably in this area by reducing internal engine heat and friction. Tests show that engine oils run 42% cooler with just a 5% mix of Tufoil. Hence vehicles running on natural gas can benefit with engine oils that run...
