Waja Intermittent Fail to Start Up
mosesmk
165
32
Selangor
Hi guys. Just want to share something with you out especially for those whose driving Proton Waja. Last CNY while on my way to JB i take a break at Seremban R&R for breakfast. Take a break around 15 minute.Then went back to car then start it up.Few second after that my engine suddenly die.Try to crank back but nothing.Its cranking well just wont start.I suspect battery flat out sing the night before I do some upgrading work for my ICE. Temporally disconnect all recently make connection and yet nothing happen. Start to diagnose spark fire,OK. Take out the fuel pump and test directly,OK. Last thing was suspected the ECU.BTW there is a guy straight away approach me once notice I could not start my car. He also starts to make some call asking what possible to be wrong. He keeps saying my fuel pump faulty. Just after I take out my fuel pump and tested directly to battery he say it could be the connector. He claims that yesterday also one Waja face a same problem with me. So I take disconnect and reconnect the connector, my car start to work again. No problem till last Friday. It’s happened again. Ask the spare part the say do not sell it. So I just bought a connector from Jalan Pasar and replace it. The connector start to loose and I just can pull it like that even it should be a self lock connector. What still in my mind now, why the guy wait for me to dismantle everything and testing everything even though he knew the solution it really simple. Now I doubt, normally if Waja breakdown and they claim fuel pump does it really fuel pump that cause the problem.
DanzEterna
15,911
3,371
www.primeperdanaclub.com
R&R seremban is the most dangerous place...i created a thread about it somewhere in the car crime & security forum.
is it an indian guy? cos i had experience when i fren broke down at R&R seremban.
yeah probably that guy was vulture waiting for you to give up...
later u kena overhaul :biggrin:
because memang socket was the culprit...not fuel pump....fuel pump last a very long time....but the socket mainly didn't survive
mosesmk
165
32
Selangor
waja command problem.. yup and it's all bout the connector. not the FP
Really eh Bro. So pity for them whose asking to change the FP. Lucky for me. :)
---------- Post added at 02:51 PM ---------- 6 hour anti-bump limit - Previous post was at 02:48 PM ----------
Thanks for concern Ganz. I read the post before and aware. not indian this time. it is malay guy. think nothern from the speaking dialect.
---------- Post added at 02:55 PM ---------- 6 hour anti-bump limit - Previous post was at 02:51 PM ----------
Think you right Bro..cause once my car cannot start it straight away approach me and asking what happen. lucky i always bring my tools in car.Yes! some friend say just another extra weight. but better than my headed been chop just for small fault. at least i learn new think :biggrin:
xtremeleo
3,247
464
5,183
same case when i was doing a waja quite sum time ago,it just died while left idling. in dis case,it was really d fuel pump's fault,changing it solved d problem. plus,d old one didnt work when we tested it..
mosesmk
165
32
Selangor
I do happen to me lah Bro. Just the morning before i buy the connector. start the car, open the gate just about to step in engine die. cannot start anymore till i disconnect the connector.in my case my FP still work lah..:biggrin:
twistedichc
Jan 22, 2013
2,930
255
683
Ampang Point
last time our van driver oso got con over there, now i keep 3 of my best mech no & my fren towing truck, lucky have them as fren
Vulture henchman lurking around every where....:mad:
I had one case but was in town. My old ride have the fuel pump under the car near the rear wheel. Park outside to attend wedding dinner, Came out started the car then move a short distance died off. Came out fiddle this and that then suddenly a guy on motorbike pass by and ask what is wrong. I contact my mechanic and he came over to check. The wire to the fuel pump was loosen. Just plug back and no more problem. Suspected this guy pull the wire and waited.....:mad:
mosesmk
165
32
Selangor
nowday lot of people out there find a way to get easy money. even they have to sabotage others. the important thing they get $$$$..
---------- Post added at 04:41 PM ---------- 6 hour anti-bump limit - Previous post was at 04:39 PM ----------
lucky my cousin was a mechanic. he also got fellow for towing. so not to worried. even hen cannot come down settle the problem at least still can guide me.
Yup, nowadays must beware. Motor bike lanes also they go throw nail.....:mad:
Oops, I think we OT a bit. So how is your problem, solved?
mosesmk
165
32
Selangor
that right.last time ride from klang to shah alam alway got flat tire. cause by the nail. the best part nail shitt look like new. not rusted. must be thrown by some one..:mad:
Yes. so far no more problem.but damm my alternator already gave hint it need a replacement soon. :smokin:
ColdPlay
288
112
Bro, mind share some picture on how to remove the seat until can reach the fuel pump?
It's a straight forward job. There are 2 lock on the front bottom of the seat: left and right, pull the 2 seat lock, you can feel the seat loosen. Remove the seat. Remove another round metal cover and you see the fuel pump.
Oppss...it's the rear seat.
mosesmk
165
32
Selangor
Andy, ColdPlay already gave you instruction. If you notice below the seat got the pin. gently pull it and lift you seat. when it unlock just pull it up and pill forward a bit since the another hook on the other side. but once you pull the lock you can straight away can remove the seat. BTW does your FP problem?
Stan,
i have to say i am very pleased with the product and your service. Been using it for almost 1 year now. The car handles extremely well and comfort not much sacrifice.
currently i am using 3KG springs for front and rear. Since i need to carry my baby girl around, need to reset to really soft setting, you know la, Malaysian road so many port holes and road patches. like stock suspension or even softer. is this possible? and how much? Do i need to change spring?
thanks
ian
