alien Coating @ the detailien HIVE
seech
400
445
1,563
The detailiens will be moving to the NEW detailien HIVE soon....
Although we have not officially opened, full detailing services are available at the HIVE including alien Coating with Optimum OptiCoat.
Do contact the detailiens if you require any information or details about the detailien HIVE and services offered.
Brand new VW... the owner wanted his 2-day old ride to be protected from the harsh Malaysian weather and had arranged to alien Coat his car with Optimum Opti-Coat.
As it happened, his car was the first to be alien Coated at our new detailien HIVE.
Jetta...
Starting out with a thorough cleaning and paint inspection...
Hmmm..... judging from the stain on the plactic, it would appear that a pre-delivery polish was done.
The usual anti-rust residue quite commonly found in most new vehicles these days...
Some random scratches...
and stains...
Upon closer inspection the glue residue from protective plastic sheets could also be found especially on the edges...
Removed with alien Clean...
Interior crevices are typically not cleaned...
Now it looks new...
Even the groove in the side mirror is carefully cleaned.
Unknown stain on the lower body.
The most important aspect of coating. Surface preparation!!!
As the alien Coating forms a permanent protective layer on top of the existing paint, any surface defects that are not corrected would also be sealed in by the coating. Hence, the need to fully correct the paint before the coating is applied.
Optimum Hyper Polish with the Double-Sided Red Foam with Makita 9227C and also Optimum MicroFiber Polishing Pad with the Flex 3401 was used to perfect the paint.
It is indeed a lot harder to spot paint defects on white but if you look closely enough...
Bird dropping damage.... on a BRAND NEW CAR???
Corrected...
Random-Isoldated-Deep Scratches (RIDS)...
Corrected...
Now the paint is ready for alien Coating...
alien Coating being applied...
Done!
Awesome gloss even on white!
Headlights also coated for UV protection and to prevent yellowing.
All ready to be picked up by the owner.
More details on the detailien HIVE to come.
Do contact us if you require any detailing services or alien Coatings.
detailien HIVE
Veloc
3,234
991
Sabah
Congrats Seech and KC on your new endeavor! Nice clean facility there... I recognised whose hand is that with the gold bracelete :)
seech
400
445
1,563
Thanks Veloc. Famous hands.... :-). Drop by if ur over this way.
DarkAccoon
880
432
3,063
woot, lama tak jumpa now come out with HIVE d.
May your HIVE business be so good that it grows to be a massive HIVE... ALIEN BASE.
seech
400
445
1,563
Thanks DA. Come by if ur in the area...
seech
400
445
1,563
The owner of this brand new VW Golf GTi wanted to protect the paintwork with alien Coating powered by Optimum Opti-Coat.
Although the choice of coating is important and Optimum Opti-Coat has plenty of evidence supporting its effectiveness throughout the internet, it is just one aspect of coating a car.
The surface preparation is critical as the coating will seal in any paint defects that are uncorrected and hence the choice of detailiers to carry out the coating should not only be limited by which coatings they are using but the quality of their work before the coating is applied.
The tools for today... 3 Makitas with Optimum Double-Sided Red Foam and 2 Optimum MF compounding pads + 1 Flex 3401VRG with Optimum MF polishing pad.
VW seem to have quite a number of paint issues even when brand new. This is just a small sample of the many deep Random Isolated Deep Scratches or RIDS found throughout the body of this 'brand new' ride.
Corrected with our arsenal of specialized detailing tools. :-)
Scratches on the bumper...
Done...
More RIDS...
The B-Pillars are typically made out of plastic and are very soft and very prone to scratching... as you can see from this picture.
After...
All done and ready for coating....
Another important aspect of coating is to ensure that the corrected paint surface is as clean as possible and that all traces of compound and polish are removed to ensure maximum adherence of the coating. The entire surface is wiped down with IPA before coating.
All done awaiting to be picked up by the owner...
The beautiful telephone dial wheels were also alien Coated to protect the wheels and make them easier to clean.
Must be a VW day at the detailien HIVE...
A VW Polo in for a quick detail...
Polo vs. Golf...
The Carbon Fiber wing of the Golf was also corrected and alien coated.
Nice CF weave under the gloss...
You can still get a nice wet glossy finish on white...
Stay tuned for more from the detailien HIVE.
seech
400
445
1,563
alien Coating in progress @ the detailien HIVE...
R?
VW R...
R....
More R!!!! The distinctive dual exhaust of the VW Golf R... Nice!
Correcting the paintwork before alien Coating.... looks pretty good so far.
R....
Stay tuned for more updates from the detailiens.
seech
400
445
1,563
kc2
1,354
1,410
thedetailers.blogspot.com
while everyone is busy
i had great fun prep this before alien coat
another black beauty
f30 328
rescue and restored and re protected by alien coat
ta da
another coupe
more
my favourite
Similar threads   Forum
Car Detailing Forums
ICE -In Car Entertainment
im quite noob about meter i just wanna ask my van c22 got no rpm meter can i just buy any rpm meter and fix in to it or theres a specific ones for car that dun have rpm how do i diy it what wire do i connect to?:Not_Impressed:
and i wanna sak :
what is the purpose of this meter:
1.vaccum
2.oil temp
3.gouch
