Low offset rims
xuang26
80
508
Selangor
guys...how abbout rim 18" with 8.5j, what size of low profile tayar most suitable? 225/40/18? 235/40/18? or 245/40/18?
kUmUcHaI 11/1
536
106
39
JB - KL
You are driving Chevrolet ? Their offset about 40 max leh. If too low offset, will come out from fender. It will scratch fender when carry too many people with stock susp. Not too wide too. 40 offset with 8j can ku. 9J scratch inside with 40offset.
My accord using 18x9j offset 30, not scratch inside, just nice but need susp. change, due to just same wide as the fender. Many job la.
Look nice pocket got black hole..
xuang26
80
508
Selangor
i'm using lancer gt. Bought a set japanese use rim with size 18x 8.5j, it come with 225/45/18 tayar...but 225 look like not wide enuff for 8.5j wide. Adjust pls.
Thanks
Thanks
Yeah, 225 is just barely make it for 8.5inch rim. Best is 235 or 245. I myself am using 245 for 8.5inch.
fazidk
413
5,183
Currently using 16in 6.5jj enkei rs..planning to change new set soon (using d enkei's for bout 6 yrs...bored oredi)..thinking of 7 or 7.5jj (even 8jj max)..will n can I stil use my current rubbers of 205/45?
Thnx n rgrds
Fazid
Thnx n rgrds
Fazid
7.5 still can. If 8jj, then need to change at least to 215, better 225.
fazidk
413
5,183
Ok thnx for d info bro....x looking for d 'overstretched' look just enuff or slight at d fender...
Thnx again bro n rgrds
mADmAN
1,840
547
no need la... can still use 205 with 8jj.
there are even people who use this setup for track.... if i get 8jj oso ill be running 205 n will be using it for track oso....
can check here for an example of 15x8 n tire fitments
http://949racing.com/15x8-6ul-black.aspx
by the way....where to find 15*7.5?? got ah? wats the offset?
if can find 15*8 +35 would be damn nice...but all the 15*8 taiwan rims here come with stupid offsets :(
15x8 6UL Black
Well 8 inch rims means it's already 20.32 cm wide not including the rim's lip thickness which normally would add around 1cm. So total width can be >21cm already which means if use 215 is just about even. If use 205 of course can still install but it will already stretch/donuting a bit and rim lip protection is almost none. I know those hellaflush people even use much narrower tires but again those are not recommended. :)
fazidk
413
5,183
Hmmmmm ok so meaning 8jj is x recommended wiz 205/45 rite?dat wld 'stretch' d tire rite?meaning to say 7.5jj d 'max' for 205/45??
FYI x for track usage just daily n only occasionally 'layan'
Oh ya forgot to mention its for wira/evo/vr4...saw one wiz offset +45..is dis suitable?
Thnx again n rgrds
mADmAN
1,840
547
ive seen pix of 205/50 with 15*8...not stretched...it actually fits just nice...sidewall is practically straight...can try find pix online
i aint gonna search coz me on phone...abit the leceh
fazidk
413
5,183
Oh ok thnx...btw using 16...Was actually thinking getting 8jj but since skeptical decide to enquire n really confirm can b used or x 1st...Need to find out more expert advice n input before deciding or else b safe n get a 7 or 7.5jj:dontknow::dontknow
X wannit to look overboard or over stretch my tires (it's stil quite new)...:proud:
Well pix can be deceiving and one's perception of the term 'stretch' can also be different, but the calculation is a sure thing already as a validation. :)
xuang26
80
508
Selangor
bro 6UE5t , thanks for ur info. May i what car u r driving? any recommended tayar if i wanna change to 235/40/18. budget around RM500-RM650 per piece.
I'm driving Toyota Mark X 250G. Not sure about tire recommendation, maybe can try GT Champiro HPY, there's already a good review done by VR2 (one of ZTH active forumers), and he said it's very good value for money. I myself is now using 17' Goodyear Eagle F1-D5 which is quite good but a bit noisy. My first choice at the time was actually Yokohama Advan Sport but turns out a bit more expensive.
fazidk
413
5,183
:adore: kick ass car!!!!!!!!!!!
fazidk
413
5,183
Bro ur too modest...d car's got d looks n d go:adore:....
Btw....wats ur opinion aka advice if:
- 7.5jj
- 8jj (mayyyyybbeeee)
- 9jj (tho x likely).....
Nah, just another normal every day sedan, no where near kicking any asses! Still dreaming of owning a real kick ass car someday.
Hi guys
how come afew of my buddies on Toyotas seems to have worse fuel consumption than the day they started off w/o tuffoil ?
also, whats the dosage recommended for a Merc SLK ?
Cyb
