Front Mount Intercooler upgrade w/ stock TD04??
keen6883
Jun 25, 2012
18
503
Manila
Bros, need your inputs.
1) Since our factory setup the TD04 outlet on the upward direction (unlike TD05 downward direction) does anybody here managed to fit pipings to mate TD04 and a front mount intercooler?? would you care to share some pics??
2) TD05 from evo 4,5,6 will bolt on to our factory exhaust manifold??
I really need some help guyz, thanks advance....:wavey:
AvanT
Custom fabricator & CNC machining
360
113
1) Since our factory setup the TD04 outlet on the upward direction (unlike TD05 downward direction) does anybody here managed to fit pipings to mate TD04 and a front mount intercooler?? would you care to share some pics?? U have anyone U know whom can service a turbo, I believe U can rotate the compressor housing to have the outlet face downward like a TD05. I did thought of loosening the center cartridge and rotate it downward, but that would require a major re-routing of the lube & water lines
2) TD05 from evo 4,5,6 will bolt on to our factory exhaust manifold?? No. Airtrek TD04 turbo and exhaust manifold is single entry & bolt hole locations are different from Evo 4,5,6 TD05 twin entry turbo
keen6883
18
503
Manila
Thanks for the reply bro. I just dont think routing a custom piping starting from upward direction ending to downward to intercooler's inlet is nice thing to do. doesnt look nice I think and space consuming. So means easiest way out is to get parts from an evo4,5,6 from exhaust manifold upto turbo downpipe??
AvanT
360
113
Yea bro Keen, it's probably best to go with Evo 4,5,6,7,8,9 turbo & manifold if U want to convert to front mount intercooler =)
Guys,
2 days ago I passed a flooded place. The water was about 1 feet. Quite a bitch to drive in. I was lazy to turn back so I though just drive through it slowly. I can say that at some place, the water is quite high. Even splashed up to my alarm buzzer level while I drove through it. I know because water went in the buzzer and it sounded funny for 2 days until it dried up.
The prob is this. After passing the flood place, heck my front carpets are wet. Driver's side only. SOAKED...
