GT Radial Champiro HPY
Hi Guys,
This is the latest tyres I am using. Y rated GT Radial. Fitted them is August.
The grip so far is very encouraging and even in the wet, aquaplaning resistance is pretty good too.
The only cons is I feel they are a bit too hard, so for comfort is not good, however for kakis who likes hard corners will be good.....:driver:
nice sharing , u did use v12 before right?
V12 almost....ha! ha! Let me see if can remember the tyres used on my VR.....
Kumho RE711
Falken ST115
Yokohama ES100
Dunlop SP9000
GY F1 GS-D3
Falken FK452
Yokohama S-Drive
Toyo T1-R
GY Asymmetric
Blue Streak Stilletto
GY Asy 2
Whoa tried so many already ha! You're like a tire test driver already. Must have been travelling on the road all the time then.
As for your comment about the GT, quite surprising you mentioned it's a bit hard. Cuz normally GT Radials makes tires with a bit softer sidewalls. I've tried them before around 5-6yrs ago and they were quite soft and comfy. Maybe they have changed it now. As for grip, they're pretty decent, I say good value for money.
These are their latest Y rated UHP tyres.....even unmounted, I try to press sidewall also hard....
g4i8y0t
1,216
330
683
Kedah
This is the same tyre used in Proton Preve. Mr vr2, how about other aspects like noise level and steering feel?
Supra_Fanatics
20,673
3,998
got 16" right? Maybe I'll try next time with my 16". Don't really feel confident with XM2 in corners...
Is it? I thought they use same one as Proton Exora Bold and if correct that is the GT Radial BAX2.
If they are the HPY, noise level to me is pretty good and steering feel for my VR also good...only bumpy....ha! ha! maybe because of my adjustable too.....
---------- Post added at 09:48 PM ---------- 6 hour anti-bump limit - Previous post was at 09:46 PM ----------
HPY starts at 17", however have Model HPX directional ones in 16"
xenith
36
Mind sharing us the price?
EvolutionZ
5,000 RPM
5,027
1,448
all Preve and Exora are using this tire ...
EvolutionZ
5,000 RPM
5,027
1,448
oic ..paiseh but the grip is also good..i tried out the preve cfe (turbo)...it wont skid easily unless u hardcore it lor
Model BAX2, should be improved model over the older BAX.
This model under High Performance category. HPY is UHP.....
Preve and Exora this model.....
BAX2
Ah the one I used back then was the BAX, very similar to the one on the picture above.
Yea, the UHP one should be stiffer in general. What's the treadwear and traction rating btw? The price is very competitive.
has anyone experienced smoking brakes?? after a couple of hard stops
came to a complete halt.... at gas station.... saw there was smoke coming
from the tyres.....scary man i tot the engine was on fire.... open the hood nothing.... check the tyres.... got some tyre smell..... must be the brakes.... cuz
tyre smoke shud dissapear within 15 seconds..... and tyre smoke
is very very thick...... with that distinct rubber smell..... check the
hydraulic lines and filler level everything ok...
