Airtrek Turbo for newbies....
Airtrek-R
Sep 3, 2012
30
6
508
hi guys... i'm getting my Airtrek Turbo in a few days... have already signed the loan with the bank, just waiting for the name transfer process to complete....
i bought this car as a daily use car, as i work at a construction site, i need an AWD car (don't prefer those big 4x4).. i was looking at those Scooby Frosties, but later headache if want to service or in case if something goes wrong, there's no viable mechanic here in Penang for those EJ engines.. so i opted for the ATR instead, since i've had similar experience on 4G63T..
so far after few test drives with the car, i felt that it lacked power.. i used to own a 4G63T Satria in my younger days and comparing it to this, almost felt like driving an NA car...
so guys, i need some advice from the sifus here on the essential 1st stage mod to my ATR to atleast feel the turbine kick in.. heheh.. hope all the sifus n gurus here can give me few tips... thanks in advance... :)
kaninbu
669
104
bro,
ur younger days satria weights hardly 1tonne n atr weights around 1.5mt.
forester n airtrek is more toward sub-urban suv not a pickup truck.with daily abuse of it suspension n bushing in construction site,i don't think it will last long.
td04 kick in full boost the earliest already compare td05.want faster spooling turbo is go for bearing turbo such as garett.
stutzedward
3,416
561
HI Bro,
Congrats on your NEW RIDE.
You can't compare with your Satria 4G63T. I assume it's either VR4 or from Evo1-3. Satria + 4G63T is like paper weight + powerful engine, power to weight ratio is very high.
Airtrek is different. Here is a few reason I can tell as compared to your Satria:
- Airtrek is very heavy at over 1600kgs.
- Airtrek is Automatic Tranny
- Airtrek uses TD04 (smaller turbo)
- In stock, Airtrek pushes out only 160-170whp
However, it doesn't mean you cannot have fun. Try basic mods like full exhaust, intake and increase boost slightly. You can immediately feel the difference. Needless to say too much, you're an otai with 4G63T.
Good luck and welcome again to the gang!
stamen
104
10
Wellington, NZ
airtrek is let down by its weight and its auto gearbox..
i'd do these as basic mods:
- de-cat and good flow end muffler
- stainless / alu intercooler pipe
- tune / timing-afr adjustment
enjoy! :)
Airtrek-R
30
6
508
bro,
yeahh.. i thought so too about the power to weight ratio... i guess i was giving it a higher expectancy on the power output... which Garrett BB turbines would u recommend? i heard that to install bigger turbines u need to relocate the radiator fan...
HI Bro,
first of all, thank you.. :)
yup.. as i mentioned above i guess it's mainly due to the power to weight ratio.. it feels like a stock GSR.. fitting in a bigger turbo would require a FMIC, and the conditions of the place i work would surely damage it in a month or two... so TMIC stays put..
enjoy! :)
ya bro... thinking of those too.. but i heard that our ATR can't use SAFC? how bout E-Manage or UniChip?
lastly, what aftermarket BOV would sound nice with stock engine without any mods? cos i can't hear the stock one.. is there any lag if i chose VTA (vent to atmo) instead of maintaining VTI (vent to intake) setup? as i read somewhere that the ECU would make the mixture rich as it does not get the desired reading while shifting...
stamen
104
10
Wellington, NZ
i would just stick with stock ecu bro, most things can be done with stock ecu. I'm a newbie tuning my own stock ecu.
no idea about vent out bov, it's sort of illegal here.
Airtrek-R
30
6
508
what are u using to tune your stock ECU? mind to share?
yep, i knew bout that.. perhaps u should try GFB Stealth/Hybrid.. when i was there most friends i know were using that in NZ..
stamen
104
10
Wellington, NZ
check this thread bro, the necessary things are listed.
http://www.zerotohundred.com/newforums/mac-malaysia-airtrek-club/417479-anyone-tune-ecu-himself.html
it wasn't that cheap for me to get all those. but here every tune touch up costs about few hundreds.. so in the long run it saves me quite a bit.
on the downside, for newbie like me it's not an easy way, quite a steep learning curve and still a lot of maps/tables in the rom are unknown. tons of infos to be read on the net, but probably only a few really applicable to our trek.
thanks for the info for the bov, but at the moment there's no plan to change it :)
stutzedward
3,416
561
Airtrek-R, true that vent-out will confuse fuel mixture to be richer. Supposedly the vent out air is channeled back into the intake pipe after MAF sensor, so considerbly richer fuel setting by stock mapping.
No need aftermarket ECU, original ECU has enough parameters comparable to aftermarket ones and it can be retuned by remapping/reflashing.
Stock boost is 0.6 bar, bov sound for HKS is heard but not loud. Upping the boost to 0.9 above will give you a really loud psssst sound though.
Airtrek-R
30
6
508
thanx for the info bro.. appreciate it.. how bout other BOV like GReddy Type RS, which u can adjust the spring rate according to boost? maybe i can adjust to softer spring rate to cope with the lower boost... 0.6bar only ehh... hm... i guess upping the boost definitely needs reflashing or rechip...
how bout the fuel pump and injectors? till what level of mods can these things cope with?
---------- Post added at 07:39 PM ---------- 6 hour anti-bump limit - Previous post was at 07:37 PM ----------
ahahh.. i guess i'll need to search around for some wideband sensors then... haha..
stutzedward
3,416
561
I am using HKS SSQV. It's said to be the WORST BOV for 4G63T with high potential of engine stalling. Well, it existed in my car and was resolved after remapping done. Even adjusting the spring won't work.
Boost can be increased within 0.3 bar without remapping or upgrading the injectors. I drove with 0.3 bar incremental with stock of almost everything 1.5 years before remapping done. I only decatted at that point. :)
Airtrek-R
30
6
508
that'll be my first upgrade... ol' skool tulang ikan boost controller.. haha.. and of course an electronic boost meter... any of u guys here experience BOV fluttering before with aftermarket BOV? i'm not talking bout compressor surge, just the BOV spring fluttering... i guess that would sound cool..
last time i was using Sheepdog BOV but it could not withstand high boost (1.5-1.7bar).. with the Type-I 2nd edition SSQV (the one that has the adjustable screw at the back), i was getting compressor surge at low boost... i'm not sure bout the newer SSQV II/III/IV...
chubster
84
20
508
New Zealand
My stock bov leaked like anything so i replaced it with a ssqv setup to recirc, although i had the cut and stretch my spring to make it open properly. Using an open pod will make the sound louder
stutzedward
3,416
561
last time i was using Sheepdog BOV but it could not withstand high boost (1.5-1.7bar).. with the 1st edition SSQV (the one that has the adjustable screw at the back), i was getting compressor surge at low boost... i'm not sure bout the newer SSQV II/III/IV...
I am not sure which model of SSQV I am using. I am guessing either 2 or 3? Here is a picture. It comes together with the original HKS intercooler piping.
Airtrek-R
30
6
508
that is Type-I 2nd edition where the logo is just the emblem.. This one also got two models, one with adjustable spring rate screw and the updated one without..
Type-I 1st edition has the Super SQV lettering instead of the HKS emblem.. Type-II onwards has the fins on the sides..
---------- Post added at 10:13 AM ---------- 6 hour anti-bump limit - Previous post was at 10:09 AM ----------
btw, got my ATR yesterday evening... got myself a used HKS Type-I 1st edition SSQV that already had an adapter for EVOVII, so it was a 10mins plug-n-play job.. haha... also got myself an HKS Direct Bright Boost Meter... haven't installed yet, maybe later after work...
will post pics soon.... :biggrin:
