Waja Auto 1.6 brake problem and speed lagging
cherabeng
Aug 17, 2012
35
10
508
morning all bros and gurus
i need some advice and hope you guys can help
my waja A1.6 is about 7 years old.
recently my brake seems like not working and i have to press until to the max floor before it stops. i have sent to a mechanic and they have change the brake hose, change the brake pads and release the air bubble inside.
the problem seems to have dissapeared but after 3 weeks now i am feeling that the brake pedal sometimes is very tight and sometime very light when pressed.
I have sent to mechanic 3 times for this problem but this problem still arise
Can bros advice me what is the actual problem ?
my 2nd problem is that sometimes the waja accelerates when i floor the pedal but sometimes, even i floor the pedal, it seems to accelerate slowly like underpower or no power like that. what is this problem ar ?
this acceleration problem sometimes goes off when i shut down the engine for a while and then restart the car again. is it some sort of engine over heating ?
hope bros and gurus can advice me on what is the actual problem and recommend me a solution or place to get this fix.
thanks all bro and gurus
kazukimy
638
372
1,563
KL/Pahang
devil-home.blogspot.com
Brake - check ur booster, check ur brake pad, check ur caliper, what brand of brake fluid u r using?properly flush and change?
Engine - which engine oil viscosity u r using? how long have it been since ur last ATF fluid been change?
:smokin:
cherabeng
35
10
508
flush twice already bro. and the brake oil are those dot 4. not sure what brand but its recommended by the tyre shop.
the engine oil i think its a semi synthetic and the brand is called primo or something like that. its recommended by the tyre shop when i service my car too.
atf fluid also changed recently last month.
cherabeng
35
10
508
bro,
i check the spark plug last 3 weeks. the mechanic fella say still can use but its those normal oem spark plugs la. should i change to better ones ? what u recommend ?
air filter also change last 3 week to a brand new oem filter.
LesleyAprotto
Banned
Jun 16, 2012
1,339
287
683
Maybe its your Auto Gearbox Oil ATF needs to be changed...
The Marketplace Top Posts
my seat belt no longer pulls back by itself..after releasing, it only retracts a little bit at a vr slow pace...
so, is there anyway to repair it back to new/good working condition?? bare in mind, it should not compromise the stopping ability when it is pulled/jerked...safety first...
i havent reli seen the seat belt mechanism b4..so i was wondering, wat affects the ability of the seat belt to retract?? shud b a spring rite?? if so then it shud b rather easy to replace a new spring so that...
