Gear Oil for manual Neo
ecal echal
74
16
508
i've tried redline mtf,quite nice! but quite pricey...shifting becomes easier after using that.
but i think there must be few brands out there that are good also...or better...hehehe
devilz 78
376
9
kuala lumpur
I'm looking for a brand that can take abusive gear shifting or just a calm drive around the city or a long distance drive, proton stock gearbox oil is good?
nadziad
287
28
johor
can try castrol gearbox oil.....mine using castrol change every 20k/km...feel smooth and can spin tyre on 2nd gear...hehe
crazykatak
776
48
Subang Jaya
it is recommended to use normal transmission fluid..rather than those racing ones. yes, no doubt, those racing ones provide a smoother feel. bear in mind, racing ones are made for racing; high temperature, high stress which requires special protection from the racing transmission fluid.
a scheduled replacement of transmission would help to maintain smooth shifting and prevent premature wear.
rippytan
May 5, 2012
14
Singapore
yeah agree... u need to make sure that what is ur application. If u are those drag till rpm very high then a good quality gb oil is needed else dun waste ur money. btw i am using lucas syn SAE140. After the change my gb is smoother plus my clutch = awesome holding effect. hehe....
crazykatak
776
48
Subang Jaya
from my observation,
when the normal gear oil was used for track racing ( even at night ), oil vapor escapes the gearbox..till it drips on the floor.
then during daytime, the oil escapes the gearbox even more.
it did not happen when racing gear oil was used. a physical proof that good oil really works :D duhh
rippytan
May 5, 2012
14
Singapore
hehe yup. good racing gb oils are meant to be super tolerant to high temp in order to ensure that the gears and working even after trashing a few rounds on track. Normal oils with lower sae will lead to like u mention...
Aug 11, 2012
2
Ipoh
I've been using Toyota gear oil for my 1.6 campro, it totally rocks as I can feel that changing gear is more easier & smoother
holysniper
159
N/A
okay even though my shifting is smoother than last time, but it still cannot match other cars shifting.. :(
The Marketplace Top Posts
Hi guys,
need help & advice:adore:..
i'm planning to upgrade my waja engine 4G18 to GSR CK but need some advice from sifus which workshop in klang valley area should i send my car...
