Programmable camshafts?
SkYwAlKeR
Over 10,000 RPM!
10,146
300
5,183
ePoh ~ malacca
wow... this is something new... didnt know camshaft can be made programmable...
mADmAN
1,840
547
camshafts are mechanical items....its basically just a stick of metal...
for something to be programmable it needs to be electrical.
speed2horizon
2,798
334
1,683
VVTI, DVVT, 2nd Gen MIVEC, iVTEC... These are actually programmable...
The cams duration are are controllable via the electronic variable pulley. Which can be mapped and reprogram depending on expertise...
Example, Kiggly successfully installed an EVO 9 cam pulley into an EVO 3 and program it to vary the duration increment vs RPM for his drag application with a Haltech E11 v2(previously)
quicksilver7
313
66
So does this mean that engines with the programmable camshafts do not have the physical metal camshafts? Is it present in the current Lancer GT?
D7zul
2,697
848
Shah Alam
Camshaft looks like this .. it is NOT PROGRAMMABLE!!
Programmable ECU looks like this.. THIS IS PROGRAMMABLE!! it can advance or retard the camshaft timing..
bera
823
229
i think the right word is "variable" not "programmable"...it will make much more sense...
speed2horizon
2,798
334
1,683
Nope.. Camshaft is still camshaft. The basic duration of the cams are still there. But the duration is no longer solely determined by the cam lobe alone. It can be advance/retard electronically via a motor mounted on the pulley.
how does programmable camshafts work? any source/link?
Vanos from BMW
BMW VVT Vanos CAM Timing - YouTube
iVTEC from Honda
K-Series iVTEC VTC Cam Phasing System - In Depth - YouTube
---------- Post added at 09:30 AM ---------- 6 hour anti-bump limit - Previous post was at 09:28 AM ----------
Programmable variable camshaft....
That's more like it...
quicksilver7
313
66
Yup I know about the ability to advance or retard the cam timing. But I wanted to know if programmable camshafts mean that it's possible for the ECU to change the cam duration on it's own. At least that's what I thought it meant by the word "programmable".
bera
823
229
i think the correct term for that is "cam phasing"...programmable sound a little off to me...
simply put yes it is possible for the ecu to control the cam duration...but that i think is old technology already...nowdays some car maker incorporate both cam phasing and cam profile...
speed2horizon
2,798
334
1,683
F*ck the terminology game....
Like said, the pulley has be able to control since Haltech E11 V2 time.... That was years back...
Dual camshaft valve timing also old technology la... BMW 16 years ago already have Double Vanos in their M3 engine...
D7zul
2,697
848
Shah Alam
u can't 'control' cam duration.. u just change it with another cam..
however, u can 'control' the 'timing' of the cam using ECU..
D7zul
2,697
848
Shah Alam
Great diagram! BTW, another question based on your diagram. Reground cams would have lower lift than the stock ones right?
i think the word u searching for is 'Regrind'..
there are people who regrind their cam using a grinder machine.. but i don't recommend u to do that..
they regrind cam to get more power but not all of them successful
:wink:
quicksilver7
313
66
I see I see. What are these specific spacers? Where are they located exactly? Sorry for so many questions, I'm really curious :D
A Post Every 5 Mins
Break free from traditional ****** norms and embrace the best in casual connections.
Secret meetings, forbidden desires for the night
Genuine Females
Super casual ******
