Chassis crack
browaja
5
Hi all,
I noticed my car has a minor crack at front chassis left panel.
Could this crack be repaired? What could caused this cracked?
Really appreciate if anybody could help.
Thanks.
D7zul
2,697
848
Shah Alam
looks like a small crack..
btw, what car is that?
ken yeang
6,617
1,327
Are you sure that is the chassis crack? Sometimes, the crack could be body filler crack.
Body/chassis crack would be more serious....but can be welded back. if it the crack is extensive (meaning more crack underneath) then the panels need to be removed and repaired properly.
Cracking could be due to "whacking" of the car....
feipepe
293
13
balakong
better going to welding before extension length of crack...if not, ur car in future hard to doing any document changing...like puspakom inspection
Xploit Machine
35
5
3,008
45
Shah Alam
bit.ly
It can be sent for re-weld and secure the minor crack and to avoid the crack to extend :) .. must do A.S.A.P
browaja
5
May I know what is difference between chassis & body filler?
My car is proton waja. Could it can be repair at normal car body workshop or is there any specialist that do this kind of repair?
metal fatigue....
all old cars (more than 5years would start building p cracks)
ken yeang
6,617
1,327
Body filler are clay-like fill used for covering body surface imperfection after body repair. The malay call it simen. The simen can crack, if it is used too thick.....
Check properly at the crack, and see if it is metal crack or body filler crack...
spoon civic
403
36
terengganu
yes..thats rite..if body crack must weld quickly...
EvolutionZ
5,000 RPM
5,027
1,448
if your car is old, maybe the rust accumulated from the water containment...anyway it looks like rust n crack on the surface of yr wheel-house joint...
Hello Guys,
After considering whether buy new car or upgrade, I decide to upgrade.
I'm planning to convert my current Wira A/B 1.5(A). But it must AUTO.
So, guys from your experience and knowledge, please advice me accordingly.
This is my shortlist:-
1)4G91 DOHC (A) 115ps
2)4G92 DOHC (A) Non-Mivec 145ps
3)4G93 DOHC (A) NA ECI-Multi 140ps
4)4G93 DOHC (A) NA GDI 140ps/135ps
I'm concern about AUTO gear box realibility (which one is the best). How about spare parts and performance...
