wts: Viton Valve seals for various cars
compaq
1,338
70
petaling jaya
These Viton valve stem seals are designed to keep oil out of the combustion chamber and are manufactured from special material for maximum durability throughout the entire rpm range.These Viton seals are made from higher quality material and superior properties to the rubber used in the OEM seals.They are extremely resistant to heat,oil additives and abrasion,with a temperature range to over 450 degrees F.
Some cars available in 8pcs Blue Viton seals for exhaust and 8pcs Brown Poly-acrylic for inlet.
available for some popular cars like: Mazda, Nissan, Kia, Toyota, Mitsubishi, Honda, Subaru, Hyundai
Price from rm200.00/set/16pcs onwards
Please check for ex-stock
t-012. 288 7774
My other items on sale:
d1 spec bonnet lock
http://www.zerotohundred.com/newforu...onnet-pin.html
Thermo exhaust wrap
http://www.zerotohundred.com/newforu...aust-wrap.html
Kenwood TK 3207 Walkie Talkie
http://www.zerotohundred.com/newforu...tk-3207-a.html
Viton seals B-Series
http://www.zerotohundred.com/newforu...-b-series.html
Hydraulic lifters for 4G63 Mitsubishi
http://www.zerotohundred.com/newforu...mitsubihi.html
Ralliart F Strut bar for VR4
http://www.zerotohundred.com/newforu...strut-bar.html
Cusco Oil Catch tank
http://www.zerotohundred.com/newforu...atch-tank.html
Dixel Fuel Booster
http://www.zerotohundred.com/newforu...post1063857266
VTTR Big Brakes
http://www.zerotohundred.com/newforu...post1063858400
M7 Performance products
http://www.zerotohundred.com/newforu...post1063858585
does anyone noe da max spring diameter can a satria take at the rear????
those original satria rear suspension mount, can take wat diameter? anyone noes? urgent...!!! coz i hav a tein HA, which uses a taper styled spring, its smaller diameter at da bottom n bigger on the top...its 70mm at bottom 90mm on da top...
http://www.jaydm.com/tein/standard.htm - can refer ere for da type of spring im talkin bout
thanks
