M7 RACING METER SMD 60MM
- Accurate electric meter with stepping motor.
- Back light dimmer function that operates with illumination switch for better view in the dark.
- Warning function.LED flashes when the value exceeds the adjustable warning limit.
- Peak hold function. Peak value can be memorized and recalled.
- Sensor short circuit notification function.
- No live unit (link unit) is needed.
- Only one power supply connection is required for multiple meters.
OPTION PARTS :
1. BOOSTER SENSOR SET
2. EXHAUST TEMP SENSOR SET
3. TEMP SENSOR SET
4. PRESS SENSOR SET
OPTION PARTS :
3. TEMP SENSOR SET
4. PRESS SENSOR SET
