Coil-On-Plug(Non CDI, PNP type)
pangyau
1,153
302
1,683
Malaysia
Hi all,
Any of you tried Coil-On-Plug(Non CDI, PNP type)?
Reason of looking due to miss-fire.
1. While on WOT (Wide Open Throttle) at RPM4-5K.
2. Normal cruising then sudden accelerate to overtake.
Done:-
1. Change the plug & check the gap (NGK BPR8EIX)
2. Check the hoses & change my IC piping (upper/lower).
Before & After IC ping change….Still the same.
3. Change the plug cable to NGK & Stock.
4. Clean the Throttle Body (TB).
The ride is stock condition.
Last bet is the Ignition Coil problem.
No option to test/borrow from other E owner.
Probably need to buy then test again.
For COP, which is suitable (brand, price & available in here?)
pangyau
1,153
302
1,683
Malaysia
H22-C,
This unit only available in US.
Actually looking forward from any local source/review.
PabloIceman
3,083
291
1,683
Sparktech have in Singapore also ... some of the vendors bring in. Otherwise Okada Plasmas.
pangyau
1,153
302
1,683
Malaysia
PabloIceman,
Could you guide me where in SG & estimated price.
Any body use it before...?
PabloIceman
3,083
291
1,683
pangyau
1,153
302
1,683
Malaysia
Base on my reading (on Net).
The CDI unit require aftermarket ECU to control/utilise it.
The the unit have different set E1-E8 than for E9.
According to Spark Tech website it seem not compatible on E8MR.
pangyau
1,153
302
1,683
Malaysia
With all this aftermarket Coil (the price very subjective).
What are the positive/negative impact on the stock ride?
Any comment very much appreciated.
AlucarD
1,079
115
5,163
CDI can be used with all cars irregardless if using stock or aftermarket ecu. So long as the CDI box can take the signal from your igniter or ecu. What is not compatible is the coils. CDI will not work with certain coils with a build in ignitor. In d CT9A case, you will need to replace the coils to "dumb" COP type coils or get a compatible OEM coil from d pajero family to work. Mitsubishi is using wasted spark so a CDI box will work with it if it can take the signal. It is when you want to go to sequential and this is where you will need an ECU that can do this and to control timing and dwell time.
You OEM coil is just fine. I would only go COP if planning for CDI and sequential and with pencil coils. Just using COP alone may not offer much benefits. Again this depends on the coils. The pencil/AEM/sparktech type coils are better than you typical COP like the ones on car now. Just get the OEM one if your car is stock. Don't bother with the china made ones. Get original or OEM Types.
Evo's are well known to have ignition coil problem due to the heat of the engine bay. Oh, also check your CPS - cam position sensor. Did you relocate the battery and how is the grounding.
H22-C
642
74
for Okada Plasmas, it does not work with standalone ECU. that's what i heard.
just in case if u change to standalone in future.
pangyau
1,153
302
1,683
Malaysia
AlucarD,
The battery still at original position.
The grounding, I had extra by using Sun Auto Ingnition Blade.
Cam Position Sensor (CPS) possibility the culprit?
What reason the sensor to be faulty/damage?
I'll check it later...
CDI systems probably suitable to modded+high power engine.
Also swapping to Pajero parts & try and error cannot be done at this time.
That's the reason for Non-CDI type as my preference.
Take note on your recommendation on Pencil/AEM/Sparktech
H22-C,
Any review could you share about the unit?
Just PNP & remove the existing coil?... How about the wiring/socket?
Saw a few E owners at my place, their Okada burn due to few reasons.
As the unit is expensive, so I need to be careful on choosing.
Standalone for stock ride...? some said is wasted modded to me...
As the ECU are expensive...
AlucarD
1,079
115
5,163
Friend, a faulty cps will cause misfire as well. But it will be very apparent across all rpm range. Your case is most probably coil related. No harm checking. The sparktech system is a very good unit albeit overpriced. I prefer HKS DLI if u retain the stock coil or if you go CDI. M&W or Dynatech's. But you will need new coils. A budget system will be some MSD tower coils. You can rewire them to work. They can be had for RM600-700. But you will also need some plug wires and depending on some people. The engine bay may look cluttered.
The Marketplace Top Posts
Highlights: The new car will be introduced in about 18-24 months and will be sold as a 5-door Proton in Malaysia and will be sold as a 3-door Lotus in other markets around the world.
It will be based on the Proton Emas concept that was shown in Geneva earlier this year but “heavily modified for daily use.”
In a joint press conference yesterday afternoon, both Proton Holdings...
