EG clubs/owner etc
peterj
1,321
258
1,683
Kuching
btw all sifu,if i use final 4.785 in my y21 gearbox, what effect will be? higher cruising rpm and higher fc in exchange for extra pick up?
mADmAN
1,840
547
basically....yup
mADmAN
1,840
547
thanks bro :D
aranny2001
249
7
Guys I'm going to transplant the b16a very soon, before I might regret, I wanna ask is that any major problem for the half cut you guys encounter? Especially overheat issue which I got huge trauma on it due to my current local d series engine, thx!
peterj
1,321
258
1,683
Kuching
so far so gud... no problem.....
---------- Post added at 10:28 PM ---------- 6 hour anti-bump limit - Previous post was at 10:27 PM ----------
just follow the NIKE's motto... " Just do it"
---------- Post added at 10:29 PM ---------- 6 hour anti-bump limit - Previous post was at 10:28 PM ----------
but remember to fine tune for maximum potential.... since mine before tune is sluggish, after tune,much more smoother low end torque
ddv_nk12
1,228
236
PD
I think its hard to anticipate the problems that you might encounter with the new halfcut until you have actually got it running. What you can do is.. Ask your mechanic to give you a warranty on parts or fix any problems that you face once you have got it running . This is what my mechanic always does for me.
peterj
1,321
258
1,683
Kuching
all sifu, anyone know can we fit toyota 4A supercharge piston (81mm bore, pin size 19mm) to our b16a? same bore but pin size 21mm.....for turbo set up.....pls help.. urgent matter:adore::adore::adore::adore:
aranny2001
249
7
my car engine didn't start for 2 weeks already, today when i wanted to start, the engine check light is on ( suppose to be off ), and my engine keep cranking and i couldn't start it, may i know why? my volt meter shown is at 11 volts only, it is too low cause it fail to start?
peterj
1,321
258
1,683
Kuching
maybe,since normally we get 12volt.... but from what i saw from the meter of the mechanic when checking the battery, they say 10volt and below mean ur battery dead..since urs is 11, might be other problem?:confused:
ddv_nk12
1,228
236
PD
I suspect its the battery. 2 weeks without starting... at least, the first thing I'd check is the battery.
peterj
1,321
258
1,683
Kuching
anyone help me on my post?
mADmAN
1,840
547
can be done... but u obciously need to mod the pin hole to fit 21mm
aranny2001
249
7
im just worry about the fuel pump didn't work, but my fuel tank all these while still got above half tank of fuel inside to inhibit the pump~~ :banghead:
Ling Reiden
From Facebook
185
12
www.facebook.com
my friend D-series also the same...if cold start,with engine check light on only can smooth start without dead-ing the engine....if engine warm for some distance d...the check light will gone after start it...till now my friend not really worry bout it anymore lol
mysayasan
83
1,508
Johor Bahru
Does your engine crank or you only hear tik tik tik tik sound? If tik tik tik sound, my best bet, get a jumpstart from other car battery.
aranny2001
249
7
my engine is able to crank~ just that failed to start..... it should be turn to ignition, then CEL on and can hear some sound that moving in the engine bay, then CEL off, only turn the key to crank and engine should start. but this time CEL is on , i didn't hear anything from the engine bay, i crank it and couldn't start.... fuel not supplying to the engine? what's the problem? pls help~~~:banghead:
virqai
206
393
1,563
not sure but mybe your main relay kong oledi...when cel off u should hear Tik sound from under dash near fius...it is main relay click for fuel pump.
As stated.. how to take care of it?
meaning.. what stuff to use or applied... coz it is easily get light scratches and dull in time..
will AutoSol do the job? any other products?
