turbo and exhaust piping diameter
ixeo
4,788
3,080
KL, Malaysia
not advisable though. even Honda B16A 1.6 N/A go with 2.3" pipings.
regarding that boost level if engine hp still below 150hp then sure can use 2.0inch pipe...
but if more than that sure have to go bigger like 2.3inch and 2.5inch pipe :adore:
MKMD428
876
190
5,043
johore
may I know why is it not advisable? based on normal practice or calculated CFM volume? I might learn something here.
the boost seems low...BOT perhaps?
VectorX2
268
45
if below 150 can use 2" piping, how much power can 2.5" support? any formulas to calculate that?
urban trends
77
9
1,508
Subang Jaya
hallo guys ..... first of all it depends wheteher your car is auto or manual... cause if it's an auto car it's advisable to use a smaller diameter piping cause u need a bit more backpressure so have a better low end and mid range..... if it's a manual car well it depends on your application; is it for drag, circuit racing or street use..... different sizes give different power band .... this is through my little experience....
urban trends
77
9
1,508
Subang Jaya
yes bro... if the piping is too small and there's too much back pressure it can kill your engine in the long run...... but this rarely happen cause you wont go smaller than your oem exhaust diameter.... but this always happen to car's which just had a turbo engine conversion...if seen people running for months on oem N.A diameter on a turbo engine ...... it will hurt your turbine in the long run.....
l2s_turbo
1,068
154
ooo.. so after bolt on must change piping is the best.. thanks thanks..
VectorX2
268
45
hmm, so like for oem turbo cars which are having a 1.6l engine, how big usually their exhaust usually be?
l2s_turbo
1,068
154
How about for 1000cc car, what is the correct size after bolt on?
to all sifus,
i need help on my aerospeed fuel regalutor, firstly the gauge meter no function so my mechanics can adjust it, i tried to replace a new one same problem, they try on a wira it works.. mine is a waja 1.8gx convert to 1.6 mivec manual. pls help.
2. the weird things is after converting my engine the aircond works till 90kmh after i head to 100kmh on hot air comes out, why? and how to repair it? pls help
3. my water temp meter rise n drops so does my mph meter. still using...
