Which is da best? Ron 95..shell,bhp,esso???
[H] [K] [S];1063674920 said:
View the vid lor for better understanding...
WHAT IS ENGINE KNOCKING SOUND?
put your gear at high, WOT at very low rpm... or effectively, floor the fuel pedal when the rpm couldn't make any increase (at low rpm) especially climbing hill... u will hear the knock sound (trrr... sumthing like that)
i watched the video and in my opinion, this kind of knocking not because of fuel RON value. this kind of knocking might be due to some mechanical parts failure or some valve-train mechanism not tuned/adjusted correctly. in idling (no load), the compression pressure in combustion chamber is very low.
my 2 cents only.. lets hear what taiko will say... :biggrin:
Maybe you're right. Sounds like there's a prob with the valves or lifters.
You hear a knocking sound, especially when accelerating. Just don't confused yourself between a knocking sound & ticking/tepet sound...
dohc vtec got no tepet sir HKS... since u are 600hp person, expect u are wellknow how ignition timing works with vacuum but not with piston speed...
:rofl: My bad then. People tend to make mistakes sir. I will try to get you a proper answer.
However certain causes of engine knocks besides carbon deposits or poor fuel. Maybe the ai filter clogged? Perhaps there's a tune-up issue, such as timing set improperly. During idling got em clicking sound, maybe there's issues with the valves or lifters, perhaps the engine's oil pressure is low, or there is a lot of sludge in your engine that is stopping oil from circulating properly.. Iono. Tons of possibilities...
now i agree with u sir...
Hi I am using a stream I vtec, car just arrived first petrol station I pumped caltex. Notice that I highese mileage I can climbed per liter 8.7. Is it true that car had not done their first service would consume more petrol that vehicles that have done their services(Honda stream)
Thank you
do u think that the petrol will give different fc for different cars? this is just my experience. for kancil fc is very high with petronas. it saves a lot with shell n bhp. but for integra, i find shell to be the worse. bhp is the best among all. next comes caltex and then petronas. caltex n petronas is very close. so now, i dont use shell anymore for my integra. i was keeping track of this for the past 3 months or more.
what do u think? do u get varying fc with different cars?
currrently BHP, Caltex n Petronas is good man!! the FC really nice
Esso has always been the best with most of my cars..
My MyVi 1.5 uses BHP and Caltex. I find that BHP offers a good balanced ratio of power and fuel consumption. Caltex on the other hand gives a bit more ooomph at highway speeds of above 120km/h but fuel consumption is slightly lower than BHP.
frankly speaking, which is better for turbocharged car? I pump petronas seems no power..
I have been using Petronas Ron 95 on my Myvi 1.5 for quite awhile. The performance and fuel consumption are satisfied (12.7-13.5km/L). However, I can feel the significant changes after changing those Irridium spark plugs. ( Kena conned by PERODUA Service Centre ). My car is totally lack of power and very bad fuel consumption. One fine afternoon, out of blue moon, I tried BHP Ron 95. Since then, this is my 7th full tank, it clocks 13.8-14.3km/L with 40% city, 60% highway.
First i give the characteristics of the brands...
Esso - Its neither powerful nor inferior, i use it quite often because for every 3,000 SMILES POINT (RM1-1POINT) i get RM45 worth of petrol.
Shell - I find it very gassy, thus not that powerful as compared to BHP and Petronas.
BHP - Its quite powerful as claimed by the BHP, my cars meter shows around 9.5L/100km as compared to others brands 10.5L/100km
Petronas - Average in FC but the engine really runs silent! and quite responsively powerful too..
Caltex - Not very up to my expectation, it runs noisy, less power and gives poor FC, sometimes runs like a diesel engine la...
In terms of economy the ranking is...
(1) BHP
(2) Esso
(3) Petronas
(4) Shell
(5) Caltex
But my preference in priority are
(1) Esso
(2) Petronas
(3) BHP
(4) Shell
(5) Caltex
BTW Who want to give you RM45 worth of petrol?:vroam: (for every RM3,000 petrol filled)
(1) BHP
(2) Esso
(3) Petronas
(4) Shell
(5) Caltex
(1) Esso
(2) Petronas
(3) BHP
(4) Shell
(5) Caltex
Mesra point at Petronas also can change to petrol,but forget how much to how much.. :biggrin:
That's why pump Shell better...Bonuslink can redeem easily :biggrin:
PETRON aso ok ma...got water pipe at petrol pump...no need go all the way to the tire pump area....
Not good, some ppl will take their own sweet time at the petrol fueling area. Obstructing others
from pumping petrol leh :biggrin:
Bad thing about mesra card is the point got expiry date from the time u pump after 3 year, just lost 4000 point due to expired, thats rm40 of fuel FYI, so i use all the balance for another rm40 of fuel. Cannot accumulate the point if u wan 2, but can be transfer point to other card.
Just use it at the pump, thats it, but u need to know how point many u got. Point collected is 1liter = 1point. Redeem rm1 = 100point.
A thread every 60 seconds
