discuss Evo 3 800whp!! and above
E-V-O-M-I-V-E-C
74
508
So as title to achieve this target we got rm20k for item and workmanship to achieve
so we need a t51r turbo,FIC 850cc injector,eagle conrod and piston,tomei cam,adj cam pulley,banana(manifold),fuel railing-is this necessary?-
and i still need wat item?as my engine is completely stock :)
mADmAN
1,840
547
i think in order to be able to get that much power out of ur 4G63, ur management alone will prolly take up half ur budget
E-V-O-M-I-V-E-C
74
508
with 20K how is it possible to achieve 800whp? With just management and tuning already take up around half of it. How about internal? Handling wise?
wat management need 10k==
dont need motec lar bro..haltech e6x now only how much la..
thinking of getting piston and conrod as mention above :)
handling damn gd :D
althought nt 4wd but using r888 and 4 adjustable :)
mines998
1,048
149
20k is not possible to get 800bhp only buy hardware already far more than 20k
albertkoh
419
4
not easy to get it. when getting such power, dont foget about drive shaft and gearbox as well. and the chassis can withstand the force?
gotboost33
106
12
3,018
Dude...If 20k can get 800whp......Imagine how many evo on the road nowadays with 1000whp!
mines998
1,048
149
I roughly calculate the cost if EVO3 want to get 800hp atleast 50k above excluded labor cost.
kumar22mostwanted
1,562
152
HELL!!!
you would definitely need more than 20k for 800whp
but you dont need a crazy amount either
just spend right the first time so that you dont have to upgrade again on that particular section
and spend wisely as well by getting the right equipment for your power goals and dont get anything that you know will not be sufficient in handling that power
if you are serious about this 800whp i wish you the best of luck and do keep us all here on ZTH updated about all the steps you have taken from day 1 if its not much hassle for you of course
as I think your build thread would be the talk of ZTH :biggrin:
hello to all sifus here..
Actually,i have probs with my engine..
1st is i juz install new adj cam pulley...
then after that i install new wastegate,
donno which brand but assume as imitation
size 38mm. After tuning my car,my engine was
rev with big sound..but the boost are geting low than before..
now my boost was too low..it juz 0.6bar!!!!!
but when i tight my spring w.gate,no sound are listening even
in high boost..1.1bar..:banghead:
i dont know y..should be my wastegate...
