4G93T Club
Solty8
256
31
3,028
hello guys I'm planning to do 4G93T with Mivec head 4G92 DOHC. I will be using Wiseco Turbo Pistons 81.50MM 0.5MM oversized, Duratech Conrods, ACL Race bearings and turbo not decided as yet. What parts will be replaced in this conversion any idea ? I will be using 4G92 DOHC Mivec Head, 4G92 Mivec wiring, sensors and ecu. 4G93 Block, pistons, conrods, bearings and head gaskit of 4G93T most probably 2.0MM. What else will I be needing ? I have a confusion in my mind which water should I use ? 4G93 or 4G92 DOHC pump ?
This is the terbalik version aka CM5A and CK series ? Or the older CD5A series ? I think u need computer management since ur mixing mivec and 4g93T tech, u could try askin a few sifu who manage to mix n match successfully, as far as i know if u use mivec ecu, how can it control the fuel ? Turbo need very good fuel control le too lean or too rich and u will have problems later. Most of the problems come if ur too lean tho, rich usually is ok. :biggrin:
Just wan to reconfirm, anyone encounter abit of engine whine ? Not the tepet sound it's abit like grinding sound. I change everything like bearing, belt, only cam gear didn't change. When idling can hear like grek grek grek den nothing den grek grek grek den nothing. I try to get the sound later once the car is in my hands now tidying up the interior and finishin sum touch up.
Anyone can share what item u guys use to stick into the ori bypass valve hole ? I found those rubber stopper from plumbing shop but my mech say it's too soft, scare it might not stand the heat and melt or get sucked into the turbo.
ahmedshaikhani
114
56
Thank you sir for your kind reply. I am using CK4A as it is a Mitsubishi Lancer 2006 Model. I will be going for a standalone ecu for tuning[Fueling, Timing..etc]. But I need a good standalone ecu which has every function anti-lag, stepper motor, launch limiter, mivec controller etc. My aim is for drag no streeting. I have a GT30R lying with me but need to change its housing as it is too big any suggestions for housing ? One thing more can I start my car and run perfectly with stock ecu. The engine came up with Automatic transmission and I am gonna swap manual gear box. Is it just plug in manual gear box or do I need to play with wiring ? In mitsubishi do they have the same ecu for auto and manual transmission ?
Solty8
256
31
3,028
Stand alone will be better for your case, bout the turbo maybe u can try hybrid with evo 4 - 6.5 ? If the GT30R is a brandnew turbo then maybe u can try to customise manifold for it ? If u wanna change gearbox i believe it's pnp but depends on which gearbox u r using ? And ur speedometer might need to change if u want it to look neat I have seen people usin auto speedo with manual just ignore the 1,2,3,4,n,p thingy. Btw depends if ur goin for 4WD or 2WD ? Since u mention drag I suppose it will be a 4wd setup ? CK4A is mivec right ? It should be the engine ? 2006 u should be using CS body lancer i think ?
From the way u mention I think ur not from Malaysia ?
Mitsubishi Mirage - all pics, specs, parts and prices
Solty8
256
31
3,028
hi wanna know 4g93 gsr n 4g93 gdi turbo manifold the same?
I never compare side by side b4, but I assume it's diff coz one is from the E4-6.5 generation another is from E7-E9 gen ?
Maybe u can try source E7 parts ? I will try to dig more info bout the parts for gdi. :biggrin:
nikolaiski
88
36
a 4G93 GSR manifold will NOT fit a 4G93GDI without modding tge location of the turbo, etc..I assume this is e CS5A
---------- Post added at 08:00 AM ---------- 6 hour anti-bump limit - Previous post was at 02:40 AM ----------
forgot to add..if u want the downpipe frm an airtrek turbo will fit
Solty8
256
31
3,028
I assume it's the CM5A 4G93 GSR ? or is it the CD5A ? CD the timing belt is on right, CM and CS both the timing belt is on left.
nikolaiski
88
36
yup since gdi only have terbalik punya version..i know the gdi and gsr manifolds cannot swap because the cs5a tf035 and cm5a td04l tapak isnt the same, so u have to swap one shot if u want with the lancer cs5a
Solty8
256
31
3,028
hey guys.. does the auto gearbox for 4g93t last long? because i m thinking to get an used car with 4g93t auto...
thx for ur answer =p
The ori 1.5 DOHC Triptonic I got gearbox problem b4, this is due to oil change not done properly, other friends with 4G93T triptonic never have major prob, most problem occur from bad oil or boost too much till gearbox can't withstand the power else everything is good without problem.
U can always change to manual later if u find that the triptonic gearbox is not ur cuppa tea. :proud:
weaponzero
51
2
508
Philippines
Hi Guys! Need your advise here! i recently installed walbro 255lph FP to my 93t. i have my FPR but it feels heavy on the run, do i need to retune my E-manage to resolve the issue? or replace my stock injectors to a much higher one? thanks!
Adeen
2,726
6
kl
IMHO u should retune ur emanage since now ur pumping more fuel to the engine..
more fuel to the engine would make ur engine feel more heavy...
weaponzero
51
2
508
Philippines
Thanks!! I also plan to install 450cc injectors before the retune (save time and money). But what would it gain from upgrading from 390cc to 450cc injectors @ stock boost? thanks again!
Adeen
2,726
6
kl
if ur running stock boost, it wouldn't make u gain much...
ppl usually change injectors to boost higher than stock...
if u plan to boost above 1bar than it would be better with bigger injectors...
and if u plan to upgrade in the future....bigger injectors would be useful...
i have a question to ask. why whenever i try to drive a large injector of low impedence (peak & hold type) via a resistor pack to a vehicle wid existing high impedence injector system i get this trouble of getting the car to idle on the 1st start. i have to wind down the fuel pressure till very low around 1.8bar in order to get started. starting up wid a low duty cycle couldnt help much wid stock fuel press as it seems doesnt response ... and once it ticks, i foul the plugs.
why ah..? can...
