better gearbox for a33 cefiro?
imperialrealcs
70
is there any better gearbox than the ageing 4 speeder box in our a33? i notice the latest teana is using cvt gearbox. issit compatible with our car? seriously 3L with 4 speeder is a damn waste!
12savefuel
195
75
I don't think there is a better trans for A33/A32 except a manual. CVT is really smooth but cannot handle much power and torque. It will be definitely less reliable than an regular auto especially if you drive the car hard often. Not sure the teana CVT is a belt or torodial system. Need to do some googling. Found it, using JATCO belt. US people saying it last about only 100,000 miles = 160,000km. Which is expected from a CVT. Currently CVT cannot beat a regular auto with clutch and gear in terms or reliability. Mostly due to slippage and heat management.
monsterhks
570
change to manual la~~~
i hav A33 manual complete set
flywheel , bracket , gear level all complete
RM2500
016 623 0313 jun
12savefuel
195
75
Monsterhks what clutch do we look for if we want to fit the manual gearbox?
imperialrealcs
70
but clutch in such car pretty much defeat the purpose of owning one :(
i just dun like the idea of 4 speeder box for 3L lol
sb3
1,141
14
5,138
Totally agreed! In the US , ppl use the Maxima (same model as the cefiro in MY) to compete in 1/4mile races with their manual gearbox! Which means this car can be a luxury vip or a sports saloon! In taiwan you can see lots of broken down cvts which I've seen in a mag. According to the mag, CVT g/box can only last for 100,000 miles or 5years depending on the usage of the car before the belt start to give problems. I think thats why the Scooby gave up their CVT development.
---------- Post added at 11:46 PM ---------- 6 hour anti-bump limit - Previous post was at 11:44 PM ----------
RM2500
016 623 0313 jun
Can it be fitted to A32 model?
doraemon98
202
6
Cannot get the belt replaced?
weikee
924
15
Last time when my friend had the first generation SR20VE, it use CVT steel belt. The belt break into millions pieces. It just can't handle 200hp and torture.
sb3
1,141
14
5,138
Why is the MT so expensive ? If 1k+ , I change oledi.
weikee
924
15
Cause 1/2 cut is expensive, and you need many things. Not only the G.box and stick. You need a difference engine rear mount, maybe cross member, interior you need the center console, than the clutch pedal, clutch pump, and brake pedal.
seizai
937
brake pedal? :confused:
weikee
924
15
You want to use back the auto brake pedal? Press clutch accidental press brake how?
Hi there sifus! I wanted to ask for my car. I just got it like couple of days ago going on 350km already on the ODOMETER.
Somehow, havent' got my 1st service yet though. Wanted to ask for advises.
Here is my plan.
1.Changing tire rims from 14" to 15", probably normal ones. Looked around a lot people say stabilizes the car and better comfort. What do you guys think? Around RM1500 with tires together.
2.Changing light weighted crank pulleys, does this improve anything? I heard it...
