Voltage stabilizer & grounding cables
xi4n9
Feb 26, 2011
Car radio's turn off(press) and on(release) when brake
i have some problem nowadays during pressing break that time, my radio will shut off for about one second and switch on back again, all lights and headlamp will dim out and light back a while as well. i wonder what problem i've occur. probably what is going on, anyone can tell?
Will it helps if i install VS and Grounding cable? or something cut lose inside?i've never touch anything before. if my negative terminal of the battery cable abit "sot" is this the problem which link to brake and radio/light?
kumar22mostwanted
1,562
152
HELL!!!
I wanted to ask about the product above, do you guys install these items? i have some problem nowadays during pressing break that time, my radio will shut off for about one second and switch on back again, all lights and headlamp will dim out and light back a while as well. i wonder what problem i've occur. probably what is going on, anyone can tell?
sounds like something went wrong with the installation
did this only happen after you installed the volt stabiliser and groundings?
xi4n9
no, i mean does this 2 items help my problem bro. =(
cause my car not break sure will off and on the radio, lights got dim. do u guys install such items above?
that maybe actually your original grounding wire got some problem like damaged or not in good condition (especially old car)
so when u install another grounding kit...then surely it helps to cure....but not solving the true problem....maybe u shud double check your car wiring back to properly troubleshoot the problem back...
and voltage stabilizer as the name suggest that it helps reduce voltage drop/spike whenever got current load/unload (such as a/c on-off and light on-off)
nathanraja45
28
503
Selangor
Bro check whether your battery charge is ok...try to see if ur alternator is charging your battery...Easiest way 2 know whether ur alternator is working is by disconnecting negative terminal of ur battery when its running...
Between HWL adjustable suspension and GREEDY adjustable suspension,which one is the best??:nurse:
