Kancil 850 Turbo..
D7zul
2,697
848
Shah Alam
Hello again..
I just wanna inform u guyz that my co-worker currently playing Plug n play with his Kancil 850..
the specs are :
- L2 head, turbine, intercooler, computer box
- stock/standard piston, con rod, crankshaft, bottom..
i've told him about the engine internal is not too strong.. but he still wanna go on with it
Any advice u guyz wanna give him?
:driver:
D7zul
2,697
848
Shah Alam
hahaha.. i've seen him in action..
sure kaw-kaw tekan..
anywayz, how much boost u guyz think it's save for this 'hybrid'?
0.5 bar? i think..
dr_snape_79
530
42
Perak
Ya me too. As long as not exceed 1.0 bar is still ok. If tekan kaw-kaw, 0.5 bar also can pecah.
DanzEterna
15,911
3,371
www.primeperdanaclub.com
my bro in law also did the same thing, dunno car out from workshop edi or not?
need sifu papagoines to elaborate more on this...
---------- Post added at 02:54 PM ---------- 6 hour anti-bump limit - Previous post was at 02:54 PM ----------
can turbo use n/a pistons (high compression)?
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
haiya bro... no sifu la...
but from my fren, its ok as long as boosting below 0.5bar... but don't revv more than 6krpm.... get a oil squirters for the pistons as well
xtremeleo
3,247
464
5,183
yes, u definitely can, iam using dis setup in d charade iam working on now. i call it a no-drama setup, lol. just boost and go jer
Veloc
3,234
991
Sabah
I think it is fine... General rule of thumb is keep 0.4 bar and below. 0.5 is risky already. For a bit more detail concerning flow, hit up bro xtremeleo.
Also, don't forget metal head gasket. Thicker ones, >1.2mm better.
Update us please!!!
xtremeleo
3,247
464
5,183
oil squirters rnt necessary, good oil is
---------- Post added at 07:53 PM ---------- 6 hour anti-bump limit - Previous post was at 07:52 PM ----------
Update us please!!!
id get a 1.8mm, or better yet a 2mm
Veloc
3,234
991
Sabah
Bro... Yes la.. but if the gasket too thick, wouldn't the low end torque suffer a bit? I mean before the boost kick in...
xtremeleo
3,247
464
5,183
the high compression pistons will take care when boost is off, plus there is a way to tune for response for this kinda setup :)
Veloc
3,234
991
Sabah
So for low boost, the combination should be something like:
high comp pistons + thicker gasket
or
lower comp piston + not so thick gasket
is it?
if tight budget..stock 850cc piston+thick gasket...
and pray for the conrod to withstand the pressure....boost not to exceed 0.6bar...if boost spiked during heavy acceleration..pray hard.... :biggrin:
papagoines
Orang Tua
2,024
376
1,683
Rawang/Selangor
thanks for the heads up bro xtremeleo (see DanzEterna, me no sifu la) .... but then oil squirter + a good oil is better rite?
...I'm having a chat before with lots of ol timer of kei-car.... some them race them on the track for the heck of it... they say, 660cc stroke is ideal.. any longer it'll make the top end suffer... even in japan, they max out at 719cc stroke...
...izzit true?
My car have this kind of problem recently,when accelerate until 4K RPM the car will stumble/Hesitate "act just like a rev limiter" sometime back off the accelerator and push it again it ill go fine.....and when the hesitation happens if i keep on accelerating sometime knocking will happen.......
I've checked the fuel pressure and everything seem fine,could it be spark plug or could it running too rich or too lean,i really can't figure this out:banghead:,thanks for any help =)
