Wira A/B special edition wheel on Iswara LMST?
saweet999
May 10, 2011
35
508
Hi ive got an Iswara LMST, Im asking if the stock 205 wide, 15 inch wheel and tyre from the wira special edition would fit well on my iswara with out rubbing?
Skyfiro A32
82
1,508
Bro saweet9999~FYI, wira will running wit 100pcd wheel while saga is running wit 114.3pcd wheel.
My family own a saga Lmst as well which i put in 195/50/15 tyre.Its fit enuf w/o any problem.205 u might facing some problem wen u r in a U turn or even parking lot
*Correct me if i'm wrong :driver:
yeehau86
Feb 10, 2007
2,856
2,425
Wira Special Edition rims are 16 inch
Yup, 205/45/R16 tyres and PCD is 100 for Wira, Iswara is 114.3, unless you get those 8 holes rims.
EvolutionZ
5,000 RPM
5,027
1,448
u can fix perdana rims or gen2 rims into yr saga.....wira i am afraid cant
saweet999
35
508
hmm thnx alot guys, what is pcd? is it the distance between the bolts? i took a look at a special edition wira A/B the other day with the origional wheels and the tyre said 16 you guys are right i was wrong. i guess when i change my tires i will just go for 195 wide. ill look into the persona or perdana rims and see how they look.
Perdana should be 16", maybe look at Persona one. You can also scout for after market used rims. A lot in the market
