Ideal Temp (ZZT231)
ezianevo
44
1,508
Hi everyone,
Got this car few months back. Just curious on ideal temperature for this car.
In my case, every cold start-up my RPM will hike until 2000 and maintain at 1500. What I noticed, it takes at least 15 - 30 minutes (depends on ambient temperature) to reach ideal temperature which i feel it is too long. Or is it normal?
When I drove the car during night, the temperature of the engine very slow to reach the ideal temperature even after 30 minutes of driving.
I noticed white smoke come from exhaust but not too obvious and also with smell of unburnt fuel. My car also have very bad gas millage. So far no any indication of CEL.
Anyone got any idea what can cause this thing happen?
markblurberry
115
20
Hi Bro,
The white smoke is during the morning engine warm up or everytime u drive? Causes of white smoke and unburn fuel can be quite a few symptoms - inefficient combustion, ignition problem - weak spark plugs, or even can be sign of brake pump giving way.....:idea:
ezianevo
44
1,508
Hi Bro,
Hi markblurberry,
The white smoke during morning start-up is very noticeable but barely can be seen when driving.
Spark plug has been replaced. No changes. Brake pump? How can brake pump affect the engine temperature?
xtremeleo
3,247
464
5,183
i think u r either 1.lacking a thermostat or 2. the thermostat is stuck open, leading the coolant to circulate non-stop. dis is the reason y ur engine is taking a very long time to warm up, fyi it shud take only around 4minutes for a vehicle to warm up sufficiently.
an engine needs to warm up in the shortest time to 1. decrease the amount of wear and tear, to warm the engine oil to its optimum operating temperature, as it was designed to work best at a certain temperature 2. keep fc to a minimum.
iam positive, for now, the smoke u are seeing is water vapor coming outta the zorst, a typical thing when u have rich fueling. the ecu richen the fueling on start-up to heat the engine up asap, in ur case the ecu keeps on sensing dat u need to heat the engine up so it richen the fuel mixture, which gives u a high fc value
ezianevo
44
1,508
Hi xtremeleo,
Thank you for your brilliant reply. I see. From your explanation it really make sense why i have this problem. Is it only takes 4 minutes to reach ideal temperature?
So do i need to replace the thermostat or is it can be repaired? How much it cost to replace that thermostat? Are they universal?
Sorry if asking too many questions. I don't have much knowledge about car.
xtremeleo
3,247
464
5,183
i dunno if u have a unit installed, but its not, then get a new one. cheap2 jer, no worries.
malu bertanyea sesat jalan, dont get lost, just ask away, dont worry too much about it.
Barbarian
625
24
3,018
www.myjsoc.com
yup.... agree with xtremeleo on the thermostat.... new thermostat cheap cheap.... mine was stucked open and I think it was about RM100 to replace it with ori toyota part.....
white smoke while start up could be due to valve seal too.....
markblurberry
115
20
Hi Bro extremeleo,
Does this means replacing the thermostat will also solve the issue with white vapor coming out of the exhaust?
Well it happens to my prev toyota where white smoke were literally gushing out, and foreman detected brake pump damage..
xtremeleo
3,247
464
5,183
Hi Bro extremeleo,
not necessarily, it depends on the if it is really water vapour or engine oil smoke. in this instances, iam assuming the engine is still in a healthy condition. there is sumthing called "cylinder bore wash" which is caused by too rich a mixture, this bores the cylinder walls at a certain rate when dat extra fuel injected in the combustion chambers thins down the lube on the walls and boring them out. again, i dont think the engine has reached to dis state, at least not yet.
even with the thermostat in, the ecu will richen the mixture to warm the engine up asap, but once it has reached d preset/optimum temperature, it will fuel up according to the revv/tps opening/map reading/etc. witout a thermostat installed, the coolant temperature will be kept cold for longer, and the ecu will keep on fueling for warm up. in fact, the engine may not be brought up to an optimum temperature and the ecu will always fuel for warming up, not good for fc imo
iam still thinking y a brake pump damage wud give u white smoke outta the zorst..
Barbarian
625
24
3,018
www.myjsoc.com
many many possibilities for 'white' smoke..... maybe your gasket koyak..... rad leaking into your combustion chamber... :) hehehheeee..... bet you are trembling rite now....
extremeleo... I'm confused.... running richer makes the engine cooler or hotter?? oil temp will be lower if I run rich..... running lean causes it to go up higher.... that's my observation.....
xtremeleo
3,247
464
5,183
too rich, it becomes colder, so much so dat the engine may able to die. richer for warming up asap, to sustain revv
Barbarian
625
24
3,018
www.myjsoc.com
huh?? :hmmmm2:
lets say, at idle.... running at 14.7 and 13 O2 ratio... which will warm up the car faster? I do know that when the coolant is below optimum temp, engine will be running richer to protect the engine.... at the same time, we tune it a tad richer if oil temp sky rockets easily......
xtremeleo
3,247
464
5,183
huh?? :hmmmm2:
y do u need this info sir? i suggest u let the ecu do its job for the warming up process
ezianevo
44
1,508
thank you xtremeleo for your prompt advice, i will get the new thermostat asap.
i will update the result once replaced.
ezianevo
44
1,508
Hi Barbarian,
That thermostat is it specifically for Toyota Celica only or it is can suite all Toyota cars?
To all drivers who did a drum brake to disc brake conversion, mind sharing some knowledge with me? I know the handbrake cable issue is one :burnout:
