Tomei gold edition fuel pressure regulator warranty is provide
yung
Aug 15, 2010
2,422
6
638
When the injectors and fuel pump are upgraded to a larger flow setup the stock fuel pressure regulator will not be enough to suit the required pressures for the new setup. Also the stock is already preset to from factory for the standard setup and non adjustable so it will be restricting the tuning potential of the car. The TOMEI Fuel Pressure Regulator will ensure stable pressures are supplied with the oversized diaphragm. This special design has proven to maintain the required pressure levels with any adjustments made.
The Hard Anodizing finish adds more protection to the Regulator since the Regulator will spend it's time in a harsh environment. This finish helps protect the thick membrane from harmful grit and grime and with the additional resistance to corrosion and heat and electrical insulation these aspects help maximize its durability and safety
Our Regulators are supplied with 2 of each AN6 and #8 nipple connectors which are the most popular type of fitments for fuel piping. Ready to install and use from the box.
Adjustable from 20 psi to maximum fuel pump capacity
Maintains stable fuel pressure at high hp levels
sensitive adjustment allows setting of optimum fuel pressure
warranty is provide
guaranty cheapest in town rm150nego
we provide postage also
SS motorspot | Facebook
yung
2,422
6
638
bump.
---------- Post added 03-12-2011 at 01:24 AM ---------- 6 hour anti-bump limit - Previous post was 03-11-2011 at 09:40 PM ----------
bump...
---------- Post added at 04:37 AM ---------- 6 hour anti-bump limit - Previous post was at 01:24 AM ----------
bump..
skyboy
699
34
KUL
Hi Sorry to interrupt.. just checkin if this ori or replica.. kindly advice..
yung
2,422
6
638
35&37 wangsa setia 1,wangsa melawati 53300
nearby wangsa maju lrt station
014-6411291(yung)
yung
2,422
6
638
my contact
35%37 wangsa setia 1,wangsa melawati 53300 kl
my phone number 014-6411 291 (yung)
The injection of fun and spirited driving back into the Toyota brand is going well and strong as Toyota will be unveiling a new convertible sports hybrid concept at the Nurburgring 24 Hours. Although first displayed at the 2010 Tokyo Auto Salon, the concept, co-developed with Gazoo Racing, has been updated and will be introduced once again as the GRMN Hybrid Concept II.
Power will come from a petrol V6...
