vios auto.. recommend exhaust system ?
viosqtd8820
130
12
my current setup.. but i kinda planning to change my direct exhaust but was worry that i will kill my performace
before started i would like to asked sifu sifu here..
i will list up what i still remember on my mod..
4-1 Custom S/S main ford
Hurricane drop-in aluminum filter
Lighten weight pulley (forgot the name liaw but yea it very light)
pivot raizin VSE
Mantola Exhaust i think is cap ayam but is direct punya... 2.5inch
Camcon VVTI controller piggy back (remove liaw because no people at bintulu know how to tune :banghead::banghead:
currently clock 9.48sec to 100kmh.. from apexi RSM
but my fuel damn full pump only can drive 380KM only.. whiles other can reach 6++ KM..
My car drink fuel like monster , but car acceleration very slow :banghead:.. if drive fuel fast car very fast nevermind hahahahha ~
what shall i do now ? i was thinking because of the exhaust not suitable for my vios ?
any reply in this would be highly appricated
tq :adore:
xtremeleo
3,247
464
5,183
Re: vios auto.. recommand exhaust system ?
iam leaning to the muffler dats causing the high fc sir, for an autobox equipped engine, i wont go with a straight through unit..
viosqtd8820
130
12
Woah ~ thankx for the fast reply... so if i goes to sflow how big the inlet u are recommend ? so if i change to Sflow will it improve my performance ? :D than now ?
xtremeleo
3,247
464
5,183
sflow muffler wud be better to generate sufficient torque in the lower revv, dat translate in better pulling power from the start ie u dont have to apply as much throttle to get the same acceleration as a straight flow muffler provides, guaranteed.
i dunno what zorst pipe size u r using now, sounds a lil too big by looking at ur fc report, but i think any sflow muffler wud be better then what u r having now. my 4g91 setup is 2inch zorst pipe, and a matching sflow mufflers (yes, i have more then one muffler for this engine, i change them on needs; smaller unit for much better fc and a bigger unit for dat top end pull. usually i use the bigger unit, lol) to match the application.
come to think of it, all my cars; na and charged are using sflow mufflers, lol
lkc
113
42
petaling jaya
bro i think u should change your pipe size to 2 inch then use s-flow muffler,or u can still use back the straight flow but add bullet in middle to give some back pressure coz your car is auto,not manual,maybe this helps improve the fc a bit.
LittleWhiteWagon
1,656
187
P.J
Im leaning towards your piping size also, even built hondas run 2.3" piping and yours is a... auto vios. I suggest try changing it to 2.0" and then tell us.
All the best! :driver:
archsaviour
Jan 1, 2011
9
Hi guys,
I'm driving a Wira SE manual and need to change the exhaust system too. Just wanted to know how you guys came to recommending a 2” piping system? Is this considered the optimal setup for a 1.5L engine in terms of performance? Would there be a big difference in terms of fuel consumption (ori is 1.6”)? Would this have any effect on the lifespan of the engine?:confused:
xtremeleo
3,247
464
5,183
Hi guys,
a 2inch is actually too big for a 1.5liter, but u can match dat size with a properly selected sflow muffler. i selected mine after trying few types, and i got the one dat suits my needs/driving style.
if u r still using the std setup now, then i wud suggest u dont go and change the pipe size just yet sir, but rather get an aftermarket sflow muffler, try and see if it suits what u need. all the std engine needs is a much more breathable zorst setup, but not too much imo
engine's life span? dat depends on the tuning and how u take care of it sir
archsaviour
Jan 1, 2011
9
Thanks for the fast reply.:adore: I was also worried that 2" would be too large for my car and would make it loose too much pressure. However, I always hear that manual cars should go for straight flow while auto should go for s-flow.
My muffler and mid-box are in need of replacement (pictures in the link below) and thus is making me seriously consider replacing it from extractor back. What would you recommend? (some recommendations from other mechanics are in the link too)
The reason why I mention the engine life span was because I'm afraid the lack(or excess) pressure from the exhaust system would cause the fumes to disrupt the engine’s flow and thus ruining it. Am I worrying too much?
xtremeleo
3,247
464
5,183
yes u r, dont worry about it..
err, what link sir? i tot the original se came factory fit with a set of good flow extractor? like i said, experimen with the muffler first. the most important thing is the zorst flow characteristics, not the hardware
Veloc
3,234
991
Sabah
Agree with xtremeleo. I was also a victim of straight flow on auto gb before. Low end torque sucks. FC increase. Right after I changed back to s-flow, ok already. Besides that, I would say your 4-1 extractor has effect too. for auto, best stick with 4-2-1 and s-flow muffler. And follow the original pipe diameter. I do not know what is it, but should be form 1.8 - 2.0". for auto, all these size is already calibrated for optimum torque, power and FC. Changing it will mess up the whole set-up.
archsaviour
Jan 1, 2011
9
Ops, heres the link http://www.zerotohundred.com/newfor...eed-advice-wira-se-change-exhaust-system.html
It's good to know that it's just me worrying too much :biggrin:
Yup, I want to keep the extractor, but since both my mid-box and muffler are ruined. I was hoping to change the whole thing from behind the extractor onwards. (ie. De-cat, bullet, good aftermarket muffler, stainless steel pipings) I don’t mind spending a bit more so long as the quality is best for my car. (budget RM1.5k):driver:
What brands of mufflers would you recommend? Any good workshops I can visit?
Waiora_ProTuner
619
221
why i read somewhere saying that you never lose power with big exhaust...just need properly tuned engine..
can explain why big exhaust are bad? do you really need backpressure? or should it be zero backpressure?
xtremeleo
3,247
464
5,183
bigger zorst will indeed increase the power level, but to what rpm sir? for a road spec car, u dont want the torque to curve out at a much higher revv so much so dat u wont be able to use it frequently. ive never said a straight flow is better then an sflow or vice versa, its dependant on ur needs sir. zero backpressure? y on earth wud u want dat?
Ops, heres the link http://www.zerotohundred.com/newforu...st-system.html
u need help on customizing a set of zorst system sir? i can help with dat, i see ur budget is more den enough. please pm for more details, tq sir
Veloc
3,234
991
Sabah
Bro... Reduced back pressure is good. But not too low and especially not zero. Think of it, if back pressure is zero, some of the exhaust might flow back in the pipe ruining the flow of your exhaust. Some amount of back pressure is required to make sure the flow remains smooth and fast right until your muffler. The fast flowing exhaust is good to get scavenging effect out of your engine. I would say if you use your car a lot in the city, tune it for best low end torque. Stick to factory size +/- 0.2". For extractor, use 4-2-1. Oh ya, if yours is auto, better stick with 4-2-1, and factory piping... It kills, trust me T.T
Please do not de-cat. Let us be responsible drivers. Don't spoil environment. De-cat gives your a bit on improvement but very minor. Unless you re-do the whole system for decat from the extractor, piping, resonator, silencer, and muffler. Just doing a de-cat itself have very little effect on power but has a bad effect on environment and noise. so for that little bit power increase, better change your air-filter or iridium spark plugs :listen:
Dear bro, Can someone tell me how to modify this engine. it is tough because it is just SOCH Vtec instead of DOHC Vtec. moreover now i'm using singapore plate. what i can think of is to try on Port ad polish,UNIChip or E-manage piggy back,speed meter to check if there is speed cut or not. the rest, i do not know what to do anymore. i just feel that my current engine is so weird because on my 1st gear (auto), it can ram to oly 5500 only then change to second gear and can ram to only 6100++...
