front
There is no doubt that the Toyota 86 is an interesting and sporty platform that enthusiasts have been waiting for years, but some of them would like to get more out of the 86 right from the production lines. To show that Toyota actually listens to such demands, they went straight to work in fiddling the 86 and came out with the 14R60.
GRIFFON-587x270
Despite its weird name, you will know that this tuned version of the 86 will be a good one as it is derived from the Griffon concept. To those unaware what the Griffon concept is, it is an R&D 86 tuned by Toyota’s in-house TRD that looks great and goes really fast. It had lapped the Tsukuba circuit earlier this year with an impressive timing of 0:58.407.
p_aerodinamics01_l
p_aerodinamics05_l p_aerodinamics02_l
The goodies thrown into the 14R60 is enough to prepare it for a raceway tuner challenge. The exterior gets a whole lot of improvements via new front and rear bumpers, new side skirts, and a wide range of carbon fiber parts like the canards, roof, rear diffuser, and the swan neck rear wing.
p_aerodinamics03_l
p_tire01_l p_brake01_l
The stock wheels have been replaced with specially-designed forged magnesium wheels, wrapped around with Bridgestone’s 235/40R18 RE-11A 3.3T tires. Hiding underneath those wheels are a set of TRD mono-block calipers with 6-pot for the front and 2-pot for the rear, mated to 365mm ventilated and slotted TRD front rotors, and smaller 330mm units in the rear. The 14R60 rides on a set of height-adjustable, mono-tube, TRD-tuned dampers.
p_chassis03_l
p_engine01_l
While the brakes might indicate that the car received a boost of power, do not put your hopes up to high as the car is still a naturally-aspirated machine. Aside from some upgraded air filter and a new engine cover, the 2.0-liter FA20 boxer engine still has the same output as the standard 86 of 200-horsepower and 205Nm of torque. However, it is mated to a new six-speed, close ratio, TRD transmission that gives it better acceleration than the stock 86.
rear
There are a lot more stuff thrown in by Toyota for the 14R60, which all of them accumulates to a price tag of Y 6,300,000 Japanese Yen or RM 188,444 (before taxes). With an upgrade list shown below, do you think such price tag is justifiable?
TRD Intake system
manifold cover
center output muffler
air core engine oil cooler
stiffer bushing engine mount
mechanical 4 pinion 1.5 way differential
triple puck TRD clutch disk, and lightened flywheel
close ratio 14R-60 original transmission gear set
quick-shift lever mechanism
revised front performance rods
rear V-brace
adjustable height coil-over monotube suspension
revised rear trailing arms
front / rear lower arm revision
front toe control arms
lightened front window
front canards
carbon fiber roof
rear diffuser
rear wing
side skirt
front wide fender
lower arm air deflectors
4/2 pot Mono-block caliper brakes 2-piece rotor
Alloy magnesium ultralight wheels
Bridgestone “Spec 14R60″ Tire
EPS-CAN Engine computer box
Full Bucket Seats (TRD by BRIDE)
Carbon interior Panels
Steering wheel (Alcantara)
Rear seat-delete panels
Alcantara shift lever knob
Scuff plates
Takata “TRD” 4 Point Harness
Titanium license plate bolt
Radio and AC delete
Transmission Scuff Plate
Green tint side glass
Revised Quick ratio electric power steering
Source 1, Source 2
