can buy from hardware shop mah.... any water resistance glue which is strong enough also can la.... jz make sure u seal it up water tight or else u will see aquarium inside ur headlight....
cover wont melt so easily la... also not ask u to melt the glue till water form.... jz enough to pop out the cover can adi lor.... aiyah....
lol, is it the same side as the air filter?? if it is.... then just bore a hole
in the hibeam area for a CAI...... thats the MAIN REASON why i wanna get the glass open......
i don have heat gun,so i use this gun!haha..very easy la to open..but then i dun have any sealant to seal it back..just put it back together..as a result,no water come in..
Hi all, currently i had a vr4 engine with modify mounting on TB side, as i know if want to put in wira chassis perfectly need to use Evo TB bracket mount. now i wonder is perdana 1st gen single cam 4g63 TB are same as evo mount? pls advice me on my build
