- Joined
- Nov 13, 2007
- Messages
- 660
- Points
- 1,518
Last a week meeting with profesional engine build and Engineering Factory from Australia agree to SPONSOR set of Dog Gear for Anybody build the Evo engine under 3rd GearPerformance Racing with 1000whp for Xtreme Drag Racing.FWD or AWD it is not big deal.Lucky Guys...we bring to Australia to visit the Performance Shop and the Gear Factory.This is a Xtreme Stuff from 3rd Gear for set up 1000whp engine.
Head Parts
1.Head Chemical cleaning
2.Port and Polish
3.Over size 1mm valve
4.Stainles steel performance Valve
5.Magnus Intake Manifold
6.Head Skin
7.Injectors 1600cc x 8pc
8.Valve spring and Retainer Custom 10,000 RPM Rev.
9.Billet Cams
10.Head O ring
11.Copper Head Gasket
12.Billet Heavy Duty Head Stud set for 1400hp
13.Power Timing Belt
14.Performance New Lifter 16pc
Block Parts
1.Block Skin Deck and O ring Block
2.Block Chemical Cleaning and Print
3.Block Rebore 86.5mm
4.Custom Pistons set 86.5mm and Speacial Compression Ratio.
5.Custom Rods 1400hp
6.Race Engine and Rod Bearing
7.Custom Billet Crank 1400hp
8.Heavy Duty Engine Oil Seal
9.Heavy Duty Oil Pump
10.New Water Pump
11.Harmonic Damper Crank Pulley
12.Engine Alluminium Pulley set
13.Billet heavy duty engine stud for 1400hp
Fuel System
1.Methanol Fuel Pump 1400hp
2.Methanol/Race Fuel Filter
3.Turbosmart Methanol Fuel Regulator 1400hp
4.Custom Fuel Rail
5.Heavy Duty Fuel meter gauge
6.Fuel Pump Relay
7.Fuel Surge Tank
8.NOS set for 200hp
Fuel And Ignition Controller
1.Microtech LT10s 45psi bar map sensor with full function
2.Ignition Booster X4 box
4.Dash Logger
5.Microtech AFR meter kit
6.MSD Blaster Ignition Coils 45,000 volt 4 pc
7.MSD custom Ignition Plug cable
8.NGK spark plug for Methanol/Race Fuel
9.High Performance Battery Turbo Charger.
Turbo System
1.Custom Turbo Manifold
2.Ceramic Crome Coating Turbo manifold
3.Custom Billet Turbo Charger Duel Ceramic Ball Bearing 850whp-1100whp
4.Custom Oil pressure turbo line
5.Custom Air Box and K&N Filter to Turbo
6.Custom Intercooler
7.Aluminium Intercooler Piping
8.Intercooler Hose and Clip
9.Turbosmart RacePort Blow Off Valve
10.Turbosmart 50mm progate Wastegate
11.Turbosmart E-Boost 60psi Controller
12.Turbo oil filter for turbo oil line
SPONSOR FOR Manual Gear Box
1.Billet Custom Dog Gear set 1,2,3,4 (1400hp rated)
2.Billet Custom Dog Gear Final drive (1400hp rated)
3.Billet Custom Drive Shaft Set (1400hp rated)
4.Custom Carbon Clucth Set for (1400hp rated)
5.Custom Billet Cromoly Flywheel
6.Heavy Duty Clucth Bearing
7.Heavy Duty Clucth Pump Kit
8.Heavy Duty Clucth Fluid
9.Heavy Duty Gear oil
Tuning Option
All Engine Tuning working on the Dyno Dynamic NO ON THE ROAD TUNING.
1.Tuning 450whp to 550whp with Pump Gas (Octane 98)
2.Tuning 550whp to 850whp with Racing Fuel Q16
3.Tuning 850whp to 1000whp with Race Methano
(under Fuel system set up)
Important Note:
1.All engine set up take a 5 weeks to be done
2.Engine Build at Australia with Pro Engineering Work due to have no 100% facility in local.
3.If engine Break when tuning work on the dyno,3rd GearPerformance Racing
Will be responsible to change new part with out repayed.
4.All parts engine build under high performance factory Australia.
5.Engine Set Up for Car Go’s 10sc to 9sc bracket 1/4 mile (402meters) with a good skill Driving.
We are looking only the SERIUS Person.Pls come to my Wshop directly to Discus.
Thanks
In other word, simply direct order from them laa bro correct? errr...:hmmmm:
.. tq..
